M4D M4X deals - Astrolux WP1 and WP2 LEP
Too bad for Olight, thanks anyway
Hello my dear friends!
to start the weekend i have some great deals for my members:
Folomov prices are too good to be posted public ;)
Folomov Tour B5M
XHP50.2 2500LM Multifunctional USB Rechargeable Tactical LED Flashlight 26650
Package included:
1 x Folomov Tour B5M XHP50.2 2500LM USB Rechargeable LED Flashlight
1 x USB charging cable
1 x Flashlight holster
1 x Lanyard
1 x O-ring
1 x Clip
Folomov Tour B4M
XP-L 1200LM Multifunctional USB Rechargeable Tactical LED Flashlight 18650
Package included:
1 x Folomov Tour B4M XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
Folomov Tour B4
XP-L 1200LM Multifunctional USB Rechargeable LED Flashlight 18650
Package included:
1 x Folomov Tour B4 XP-L 1200LM Rechargeable LED Flashlight
1 x Lanyard
1 x O-ring
1 x Clip
WUBEN TO10R only US$30.15 $45.00
3x XP-G3 with high CRI 650LM Dual Switch Magnetic Tail Rechargeable Stepless Dimming LED Flashlight
Package included:
1x WUBEN TO10R Magnetic Tail USB Rechargeable LED Flashlight
1x Built-in 16340 Battery
1x USB Charging Cable
1x Lanyard
1x Mannual
1x O ring
Astrolux K1 only US$ 16.95 $26.05
with code MAXK1
XP-G3+365nm UV+Red LED 350LM
NEW DRIVER USB Stainless Steel Mini LED Keychain
after a long time the BLF Q8 is on stock again!
A real monster flashlight and result of a flashaholics project!
BLF Q8
4x XP-L 5000LM Professional Multiple Operation Procedure Super Bright LED Flashlight
my Code: M4DQ8 my price: US$ 46.50
(MRSP: ~$80)
Rofis MR70
XHP70.2 CW+XP-G2 NW
3500LM Dual Light Multifunction Rechargeable LED Flashlight
incl. ROFIS 26650 5500mAh
– presale only US$ 62.69 (4 members)
Features:
● Uses a 26650 5500mAh high-rate discharge lithium battery,the main light and side light dual light source design.
● The main light utilizes XHP70.2 P2 CW LED,output up to 3500Lumens.
● Side light utilizes XP-G2 R5 NW LED,maximum output to 200Lumens
● One-touch control all function,it is easy to operate.
● Body with Micro-USB charging,which supports up to 2A charge.
● Can be used as a mobile power supply,use the USB adapter provide power to other devices,the maxmum output to 2.2A;with a dischargercapacity reminder.
● Users constant current circuit, with high battery effciency,stable output,no flashes.
● Anti-reverse design to prevent incorrect battery installation causes the circuit damage.
● Battery power detection,charging instruction,low battery reminder function.
● With locking function prevent accidental illumination.
● One-pieces shell,the structure is stable and reliable.
● Made of aero grade aluminum alloy,premium Type III hard-anodized anti-abrasive finish.
● With flashlight self-location function.
Charging:
● Before charging,ensure that the battery is correctly loaded into the flashlight, and the tail of the flashlight has been tightened.
● Insert the charging cablle Micro USB port into the flashlight charging port,then insert the charging cable USB port into the power port to recharge.Charging light red indicates charging,green indicates charging has been completed.The flashlight can only turn on side medium mode while charging.
Package included:
1 x MR70 flashlight
1 x ROFIS 26650 5500mAh battery
1 x Charging cable
1 x Micro USB to USB adapter
1 x Holster
1 x Lanyard
1 x USB cover
1 x User manual
2 x O-ring
Maybe get a coupon for an s41s?
i find only for S42S
i got some often asked deals renewed ;)
find the codes and prices here
Brand model = my Link (please use)
HaikeLite NEW SC02 II
nitecore P12GT
Klarus G30
Nitecore MH20GT
nitecore TM16GT
ADEASKA SQ4
keeppower ICR26650 5200 for Convoy L6
Hi Max, I tried your code but Banggood came back with “This coupon only applies to specific products.” Something changed?
did you choose the china warehouse?
wow - gone fast again...
Ah yes, that’s got to be it — “ARRIVAL NOTICE” appears in place of “ADD TO CART” if selecting the China warehouse. Thanks for the explanation!
could i get code for clear convoy L6 please Martin, thanks.
Can I get a new code for XT12GT?
Current code is expired. Thank you Martin
as always – find my codes here: https://m4dm4x.com/m4d-m4x-deals/ or send me a message!
DQG Tiny 26650 3th US$48.06
7x XP-G2 NW 2500LM 4modes EDC LED Flashlight
Features:
• Utilizes 7x XP-G2 LED
• Driven by a unprotected 26650 to emit up to 2500lumens brightness
• Four easily accessible brightness levels and memory function for fast boost
• Extensive runtime up to 200 hours
• Electric reverse polarity protection
• Anti-rolling design
• Toughened ultra-clear mineral glass with anti-reflective coating
• Constructed from T6061 hard aluminum alloy
• Waterproof in accordance with IPX-8 (two meters submersible)
• Tail stand
Package included:
1 x DQG Tiny 26650 3th 7x XP-G2 EDC LED Flashlight
1 x o-rings
1PCS LiitoKala Lii-40A 4000mah US$5.94
3.7V Unprotected Flat Top Li-Ni 21700 Battery
Specification:
Product Name: 1PCS LiitoKala Lii-40A 4000mah 3.7V Unprotected Flat Top Li-Ni 21700 Battery
Brand: LiitoKala
Model: Lii-40A
Chemistry: IMR
Nominal Capacity: 4000mAh
Nominal voltage: 3.6V
Discharge: 40A Max Continuous
Positive: Flat
Rechargeable: Yes
Dimensions: 21.2mm x 70.4mm
Weight: 61.2g
Package included:
1x LiitoKala Lii-40A 4000mah 3.7V Unprotected Flat Top Li-Ni 21700 Battery
2pcs Sanyo NCR18650GA US$ 11.04
3.6V 3500mAh 10A Rechargeable Lithium Battery
Package included:
2 x Sanyo NCR18650GA 3500mAh Lithium Battery
ADEASKA SQ2 US$13.34
Intelligent LCD Display USB Rapid Battery Charger for IMR/Li-ion Ni-MH/Ni-Cd Battery
Specification:
Product name: ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger
Brand: ADEASKA
Model: SQ2
Input: DC5V/2A
Output: 4.2V±0.01 1A*2/1.48V±0.01 0.5A*2
Compatible with:
Li-ion/IMR: 10440/14500/14650/16340/16650/17650/17670/18350/17490/18500/18650/22650/26500/26650/32650
Ni-MH/Ni-Cd: AAAA/AAA/AA/A/SC/C/D
Color: Black
Weight: 137 g
Package include:
1x ADEASKA SQ2 Intelligent LCD Display USB Rapid Battery Charger
1x USB Cable
1x EU Plug(depending on what kind of package your choose)
The Astrolux S41S is on promo sale right now @ $32.95 (and it appears the same price whether the G2, G3 or Nichia versions), and appears to be usable with the generic “4BLF” 9% discount code, making it only $29.98.
If you have an Astrolux S1 18650 tube, you could also just buy the S41S head ($21.95 promo, can still apply 4BLF discount code) and attach to that to an existing S1 tube (that’s how I use mine now, the color of the head is stainless, but the body is the ordinary aluminum one [so it’s quirky mismatched colors but works; and swap the S41S shorty 18350 body tube to my S1 head…]; but it’s now lighter to carry around than full stainless body)
I got it about 2 months ago with a discount code, and its price was quite higher then ($33.96 IIRC for the Nichia).
Already ordered one the same way, should be here Monday :wink:
I think it was regular priced when I asked for a code and a few days later I noticed it on sale and used the blf code.
Under $30 I couldn’t say no
https://m4dm4x.com/lumintop-tool-ti-groupbuy/
new price 34.99 USD
only 150 left...
thanks for code Martin, ordered clear L6 with some other convoy goodies.
any chance on getting codes from banggood for the
Nitecore EA42
Nitecore MH23
Nitecore Concept 2
I realize that some are still “pre order” so if it takes a while, I am okay with that
Thanks
€U warehouse deal same price as china ;)
https://www.gearbest.com/smart-lighting/pp_361555.html?wid=91&lkid=12985583
code: YeeMIPO
price: €14,92
from Ploland Warehouse
Max Per order: 100pcs
Max Per account: 2 order times
