Cheap to produce? If you have an order for 10,000 maybe. Get a quote from a mold maker and for a small batch from an injection molding shop and get back to me. The mold alone would cost thousands.
Back on topic… I should be able to work Proto V2 into my schedule by the weekend. This will at least be the final version of the brackets. As for the handle rod I’m still set on 3/4” aluminum bar stock. For those that want bike grips y’all can slice off my grip easily and do a couple wraps of tape to make the bike grip fit. Though they might fit without tape as well, my bmx days remind me those grips took some elbow grease to get on the 7/8” bars.
3/4” bar stock with nice knurling on it is ideal in my opinion. Can be done with tubing as far as that goes, but I do like things to be rock solid so a bar… hard to beat. I’d probably be prone to reduce the end of the bar and cut threads onto it so it would screw into the bracket, do away with that screw, but that’s probably just me.
It’s actually raw G10. The stuff you normally see as knife scales? Only much thicker. Raw meaning no attempt to color it was made when it was produced. We’re used to seeing black, even a few colors these days… recently even some knife scales in the jewel hued light green of it’s raw state. It’s a high pressure laminate fiberglass/epoxy material that is extremely dense and stable.
I’ve got a few 12” rounds that are over 2” thick, they’re heavy! lol
I’ve had it for 20+ years, it was actually a 16” square sheet 13/16” thick with a hole in the center and drilled/tapped holes for mounting the machine that does the surgical procedure of knee replacements. I cut out a square on my table saw, then used an end mill bit in my table top drill press to get an L bracket shape. Sanded it to profile on my belt sander, finished sanding by hand.
