13583 posts / 0 new
contactcr
Last seen: 8 min 39 sec ago
DB Custom wrote:
… blend… XPL HI emitter
Which XPL HI and optic do you think could accomplish this? It’s hard to even find 3 different XP-L HI leds as choices from vendors or manufacturers. I would totally consider this but not even sure it could be sourced easily to mod.
ToyKeeper
ToyKeeper's picture
Last seen: 12 min 23 sec ago
DB Custom wrote:
how neat would it be if this light used 3 carefully selected tints to emit a near perfect output?
I like how my tint-mixed quads turned out. I haven’t gotten a triple to look quite right though.
It should be doable with XP-L HI and a frostic optic, but it’d probably be easier with three high-CRI Nichia 219c emitters instead, since they’re less tinted to begin with. Perhaps 4000K, 4500K, and 5000K. Together they should look pretty good, but I haven’t tried it.
I’m not sure if 10511 is frosted enough to make the tint-mixed result look good. It might be necessary to use 10508 or 10509, but that’d make it a lot floodier. 10511 might be okay if we don’t mind having a few different colors of mild artifacts.
Glov
Last seen: 6 days 16 hours ago
Please add me to the list for 1 light
bobkido
Another guy late to the game…
Please add me for one piece, thanks.
Just a simple man.
ferthur
Put me down for one, please.
I really need to remember to get in on these interest lists earlier.
Scallywag
Scallywag's picture
Last seen: 8 hours 7 min ago
I'd like to be added to the list. Thanks.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
SpAwN
SpAwN's picture
Nice Cool add me to the list for one please.
Thank you.
DB Custom
DB Custom's picture
Last seen: 1 day 40 min ago
Ah, see, I wouldn’t have thought of the 3 Nichia’s, nice call! Would love to see that even if I have to weld em in there my own self. Big Smile
Might be totally off for this thread, but is there a way to run triple channel to the 3 tints so there could be some selected mixing? You know, dial it in? That’d be cool…
ToyKeeper
ToyKeeper's picture
Not without some big changes to the hardware and firmware. It’d need a new driver, a new MCPCB, and a bunch of new code. It’d either sacrifice low-mode efficiency (and moon) by being a triple-FET design, or would sacrifice the high modes by being a 3×2×7135 design, or would need a bigger MCU and probably bigger driver to handle 6 channels instead of 3.
XD9
XD9's picture
ad me to the very late list please Big Smile
mts49
Last seen: 1 year 3 months ago
Please add me to the list for one. Thanks!
Dikkedikk
Please add me to the list for two (2). Thanks!
SoulCraves
Last seen: 5 min 42 sec ago
one for me pls!
crz6662
crz6662's picture
Last seen: 2 days 19 hours ago
teacher wrote:
Yep…. they both look good.
Yeah, but I hope it’s not bead blasted. Shiny looks so much better IMO
1st version looks like a high end light, 2nd version looks cheap.
DB Custom
DB Custom's picture
Sorry, forget I asked… Wink
On the shiny vs bead blasted, after having made a few lights from scratch and in the beginning going for a polished look, I am now learning to make a final pass that leaves “tooling marks” for some grip. The polished lights feel oily in hand and are a bit tough to hold onto, or can be. Just a thought…
Edit: for clarification… when I was first learning to use the lathe my challenge was to get a smooth near polished cut, running the feed by hand. When the gearing is used to feed at a constant feed rate there are micro lines showing the advancement of the cutting tool (most of the time) Now I am learning to replicate that by making a faster final pass to get those lines, instead of laboriously cutting slow for a smoother finish.
nqcken
Last seen: 4 days 2 hours ago
add me to the list please. I like shiny but…
ToyKeeper
ToyKeeper's picture
Sounds like one of the major signs of starting to gain mastery — after learning the rules and how to do things right, moving on to learn when and how to break the rules for added effect.
Just a couple days ago I had reason to break the rules in a song I’m making. I ended up using a chord of four notes a half-step apart… like C, C#, D, and D# all at the same time. Normally this would never happen because it sounds shrill and dissonant and one would be hard-pressed to find a chord which sounds worse… but it can, on occasion, be useful.
DB Custom
DB Custom's picture
I have always had this thing about polished. Since I was a kid, it was kind of an obsession. Once, when about 10, I got ahold of a piece of 2000 grit wet/dry sandpaper and wondered what my fingernails would look like if I polished off the fine ridges and such. So on one hand I used the paper and got the fingernails mirror finished, essentially. Then it was embarrassing dealing with the questions about why I “painted” my fingernails! lol Haven’t done that again, but still, I like polishing things for the bling effect. But, after making a few lights with “bling” I discovered it made them difficult to hold. So, compromise was needed. Smile
Finding how to make it look qood while working can sometimes be quite a chore. How many lights do we have with fins on the head, adjacent the reflector, but not so much where the heat is going, below the emitter? Aesthetics can be a bear, function can be ugly, I applaud all the manufacturer’s that figure out so many ways to make so many models…
boTy
boTy's picture
Count me in for 1!
If I can give my input I’d prefer the completely flat battery tube (so no slants) and a non-shiny finish.
Zulumoose
Zulumoose's picture
Last seen: 3 months 4 days ago
Has anyone managed to get an update on the progress with this? There is a large and growing base of support now, it would help if we had a regular status report to confirm that we are heading somewhere and not just treading water.
Beam me up!
Jiffy
This is being actively worked upon. Updates are posted more frequently on the discussion thread on the German forum:
http://www.taschenlampen-forum.de/threads/fw3a-tlf-sonderedition-in-klei...
I use Google translate to follow it:
https://translate.google.co.uk/translate?sl=auto&tl=en&js=y&prev=_t&hl=e...
A prototype was sent out a month ago to the team working on this and they’re fine tuning various things like the button and the driver. As for the design, Fritz15 said he’s not 100% satisfied with it so current shape will no doubt be balanced out.
KW
KW's picture
Please add me to the list……
cellguy
cellguy's picture
Last seen: 1 year 6 months ago
Put me down for 1.
Current Favorites:
BLF Q8, Thrunite TC20, Convoy L6
jycheang
Last seen: 8 months 3 weeks ago
1 unit for me thank you
Dewalt101
Last seen: 5 months 10 hours ago
1 for me please.
SpAwN
SpAwN's picture
Hi Zulumoose, the organizer of the BLF side for this project The Miller was sick couple weeks ago, the other forum members are trying to keep things up for him, but it is not an easy job to do so. Let’s hope that The Miller is well and come back soon to the forums. It is little worrying to see an active forum member not being online for 3 weeks, not for projects sake but with his wellness.
You can read The Miller’s post here http://budgetlightforum.com/node/58021
fritz15
fritz15's picture
Last seen: 1 year 8 months ago
We also posted our impressions here but if you’re not following every post you don’t really have any chance of finding it since the topic here receives so many more replies. And unfortunately, it’s not possible to update the original post by the miller.
Anyway, this week or next week we’ll send our feedback to Lt and then we wait until the next prototype is ready.
Zulumoose
Zulumoose's picture
Great to get some reassurance things are moving, seems every time I check out the thread it is so full of new subscribers it seems there is little else going on. Thanx guys.
Beam me up!
Firelight2
Firelight2's picture
Last seen: 5 hours 10 min ago
…. but I’m sure you could do it! Having a variable brightness AND variable tint light would be a lot of fun. Thumbs Up
Maybe make this a more expensive option, or have a separate driver and star for modders.
Jiffy
Thanks fritz15! Yes, I actually find the German thread easier to follow due to less posts even though I have to get it translated. Party
