For one quality 1080 lumens output usb rechargeable tactical and outdoor dual mode light(battery not included), how much you would like to pay on Amazon?
15 posts / 0 new
Nitefox
Nitefox's picture
less than 20
77% (20 votes)
20-25
12% (3 votes)
25-30
8% (2 votes)
30-35
4% (1 vote)
Total votes: 26
Nitefox quality products for easier outdoor and everyday lighting
Hot sale 1080 lumens outdoor and tactical dual mode USB rechargeable light UT20:
https://www.amazon.com/dp/B0746H9KYM
Edited by: Nitefox on 01/16/2018 - 06:58
Mike C
Mike C's picture
Last seen: 19 min 58 sec ago
Weird question… One can already get that under $20… Or what exactly do you mean with dual mode? Two brightness levels?
ifratos
ifratos's picture
Last seen: 2 hours 48 min ago
Vote for Under $10!
And God said, Let there be light: and there was light.( Gen.1:3)
mrheosuper
Last seen: 5 hours 10 min ago
this is quite hard question, depend on manything, for budget brand like astrolux, i want to spend less than 30$, for famous brand like olight or nitecore, fenix, my limit is somewhere 50-60$
Forgot my pen
beam0
beam0's picture
Last seen: 9 months 3 weeks ago
I think Nitefox is referring to their UT20, it has two separate mode groups: tactical and outdoor.
https://www.amazon.com/Rechargeable-Flashlight-Tactical-Handheld-Portabl...
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
beam0
beam0's picture
Like everyone else so far I voted for under $20, which could be $19.99.
At BLF we are exposed to a vast selection of similar lights in that category, and many time we are offered deals on them for around $20. A suggestion would be to set the amazon price at $29.99 and offer BLF members a promotional code for $19.99 to get some exposure, especially if it’s a new offering.
Mike C
Mike C's picture
I missed that part, thanks.
It has strobe in both mode groups Facepalm
beam0
beam0's picture
Fortunately on the Outdoors group it’s hidden (double click) (long press – 2 seconds) so it’s not part of the main loop.
Strobe is #2 on the Tactical group, but at least its not FIRST!!
V V V
Strobe FIRST group and “Tactical Assault” group:
http://budgetlightforum.com/comment/1262144#comment-1262144
MascaratumB
MascaratumB's picture
Last seen: 13 hours 5 min ago
Fortunately on the Outdoors group it’s hidden (double click) so it’s not part of the main loop.
V V V
On the “Outdoor” group, the Strobe is accessed by long pressing the side switch! Not too long or that will enter on the “tactical group”.
On the “Tactical” group it is High – Strobe – Low! On that group mode the light is operated only through the tailswitch (forward switch). The Side switch is only use to go back to the “outdoor group”, through a long click in any mode.
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 /// KLARUS: XT1C
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8  TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
beam0
beam0's picture
V V V
Thanks for clarifying, guess I confused “2 second press” with 2 presses, either that or I confused it with a different light (been looking at a few today) So I edited my post with the correction.
For the “Tactical” group I’m aware that it is High – Strobe – Low, Smile that’s why I wrote “Strobe is #2 on the Tactical group, but at least its not FIRST”
(then below I link to my post about a flashlight that has a strobe first group)
I like how the UT20 tactical group disengages the side switch completely, that will be helpful to avoid changing modes accidentally if you accidentally grip the light over the side switch.
I assume the UT20 side switch (outdoor mode) does not have an off or standby? Just Moonlight-Low-Medium-High-Moonlight-Low-Medium-High-repeat in a continuous loop correct?
MascaratumB
Eheh, no problem Wink I noticed that the “2” over there was confusing and seeing and using so many UIs result on that Big Smile
When I wrote about the Strobe groups/modes I was just reinforcing your words and helping to “separate” both groups for other people that may not be familiarized with the UT20 Wink
You’ve been reading and know how it works, but for other members seeing this for the first time, it may help to contextualize the operations Smile
Yes, you’re right! The tactical group being only operated by the tail switch is really nice, you don’t have to worry with touching or grabbing the light on the body!! Also, after using it on tactical for a while, one gets use to work with that and how to “time” the passage through the 3 modes!
That makes it good for a night walk or for places where high and strobe are easily accessible to mark your position or to “defend” yourself in some way!
About the other modes, yes, if you want, after switching it ON it goes on that loop all over again, by pressing the sie switch!
It is OFF only when you click again on the tailswitch!
Also, if you want to change the modes before switching it ON, you can half press and hold (momentary ON) the tail switch and then press the side switch to cycle through the modes! I do this sometimes as I leave it on High and want to start on Moonlight next time.
It is a momentary ON that allows mode changing! Don’t know if other lights are like this, but I find it cool Wink
 MY GIVEAWAY (FW3A)
beam0
beam0's picture
MascaratumB wrote:
Also, if you want to change the modes before switching it ON, you can half press and hold (momentary ON) the tail switch and then press the side switch to cycle through the modes! I do this sometimes as I leave it on High and want to start on Moonlight next time. It is a momentary ON that allows mode changing! Don’t know if other lights are like this, but I find it cool Wink
The side switch on my Ultrafire C20 (clone of Crelant 7G3CS) will change modes during a momentary half-press of the tail, but not really usable to set the levels as you described since it doesn’t have memory.
MascaratumB
Oh, didn’t know that! Well,normally I don’t appreciate lights with memory, but in this case, and in comparison with the Ultrafire C20, I would prefer memory with the forward switch!
BTW, I didn’t make reference to that, but the Klarus light you linked before is also very nice!! I like Klarus designs, but their UIs sometimes make me some confusion! Though, one of the lights I’d like to have is a Klarus light, the G20! The independent switches are top (for me) Big Smile
EDIT: Sorry for being off-topic! FacepalmSad
 MY GIVEAWAY (FW3A)
Mike C
Mike C's picture
That sure isn’t clear when looking at that Amazon link. If they want to cater for more potential buyers they should make that clear in the overall description.
MascaratumB
A small correction Mike C Wink
MascaratumB wrote:
On the “Outdoor” group, the Strobe is accessed by long pressing the side switch! Not too long or that will enter on the “tactical group”. On the “Tactical” group it is High – Strobe – Low! On that group mode the light is operated only through the tailswitch (forward switch). The Side switch is only use to go back to the “outdoor group”, through a long click in any mode.
Hum, Nitefox must check on that then! If the information is not completely accurate, people that don’t like strobe may “avoid” this flashlight because of bad information!
 MY GIVEAWAY (FW3A)
