1. It can transform into an angle light (rotate the head 90 degrees) or use as a straight handheld.
2. It has a magnetic base
3. Uses ANY AA battery. (I use 14500 for max output) But in an emergency can use a regular AA.
4. I can make it a headlamp by rotating the head and using the Olight headband H2R Nova Headband (uses a magnet in the cradle for fast placement and has a silicon strap to secure)
But I have also been thinking of the Klarus Mi7 (glad to see it mentioned several times here)
I simply LOVE this Rofis! Best all around AA light. (IMHO)
My wife is carrying an 18650 light in her purse and notified me last night she wanted a “smaller light”….so here i am on this thread.
I would like a AA/14500 light with usb charing built in one way or another (either in the battery or on-board charging. I see many lights suggested on this thread but very few have the usb charging option. Any suggestions for me? Budget please less than $30.
I am also open to an even smaller light than 14500.
Can someone help please?
Some have in-built charge, and I guess others have rechargeable batteries!
They are sold in several places (I normally search in AliExpress) but there other places for sure!
Also, if you want a small 18650 light with in-built charger, take a look at this thread: Folomov EDC-C4
The Jetbeam E10R is an extremely nice and small light and it features regularly in deal threads for less than $20.
The big flaw in that light is that charging a NiMh battery (like AA Eneloop) via the USB-port does not go well, the charging stops at 70 or so % from full. But if you use a 14500 in it (which has better energy density anyway) charging is fine.
Hi,
Look for the Jet Beam E10R AA / 14500 built in charge, although it has been reported the charging function will not fully charge an 14500 . For Ni-mh it works. JetBeam also has the E01R AAA size with charging function.
This is a description I’m not endorsing any particular vendor
This flashlight was delivered on January 11, 2018. It has become my all around favorite light. I chose the neutral tint option. It is a warm tint. So if it matters this is my current favorite AA/14500 flashlight.
In the AAA/10440 form factor, i’m very partial to the Ultratac K18. Possibly the brightest in it’s category, very well made and nice to look at. A USB charger add-on is also available - which is a must have to charge small cells at a moderate current not always possible on most charger.
Wow the Ultratac K18 in that website has a Nichia option. Even Ultratac’s own website doesn’t even have that. The XP-G2 version runs at 110 lumens on AAA. I wonder which Nichia emitter it uses and which tint. I would buy it if it has 4000k or 4500k tint as I really want a good AAA or AA nichia warm/neutral light.
I just got my Lumintop Tool with the 219… quite nice!
I’m not a fan of AAA lights, so I never got any Tools before, and this is my first, pretty much only because of the 219. Think it’s a 4000K 219BT, maybe 4500K, don’t recall offhand.
I didn’t know the Tool AAA came with nichia, I reflowed a 219C into mine and the result is quite nice (except for the medium > low > high UI), and once I choose my favorite AA light it’s getting another emitter from my dead D4
Hmmm. Was thinking it was just H→M→L instead of L→M→H. It “resets” to M after enough off-time? That’d suck. I’d rather have true memory, or if no memory, start on L.
Guess I didn’t play with it long enough…
Fwiw, that’s one reason I never bothered with OnTheRoad lights, ’cause they all seemed to start on M. They look quite nice otherwise.
