This one is the XXL. It’s maybe a little looser than I’d prefer, but I do like that I can get it on and off with one hand, and it’s not going to slip off that easily on its own. I hear people saying that the XL fits perfectly, but it looked a little tight to me in pictures.
Just got my OP/Tech hoodie today (XL), I sort of regret not getting the XXL, the XL is a very tight fit when putting it on. From the looks of it, the XXL is definitely not going to come off and its dimensions seem to be a better match for the BLF GT.
I may add something. I'm not sure yet. I was thinking about something cylindrical, that the head of the GT slipped down in too.
Spare batteries are my first thought. A piece of foam the thickness (length of) 18650 batteries. Cut out so the battery tube of the GT slides through, w/8-18650's (individually) around the circumference with a handle of made of strap material attached to lift it out. Here's a sketch.
I have the XXL now. It works fine. Not as snug and it stays put. I however did the opposite of you. I ordered two of the XL that are not here yet!!
Question for those who got the Op/Tech Hood Hat - Is it neoprene only or does it have a stiffener/piece of plastic along the bottom as well?
The reason I ask is because I went with the LensCoat Hoodie. It is more expensive, but there is also a pocket on the bottom of the sleeve which contains a thin piece of plastic which has additional padding on one side.
The front disc in pouch is why I prefer the Hoodies. It offers much better impact protection, fits better, and the rigid front keeps the hood from slipping around.
The LensCoat Hoodie helps protect the front element of your lens from dirt, dust, moisture and impact. The neoprene Hoodie fits easily and snugly around your lens hood or shade in either the shooting position or reversed. The Hoodie features a reinforced removable front element protection disc made from rigid plastic and firm foam to further protect your glass from damage. Great for travel and storing your lenses. The X Large fits lens hoods from 4.75” to 5.25” in diameter.
And about the XXLarge…
From the Manufacturer
The LensCoat Hoodie helps protect the front element of your lens from dirt, dust, moisture and impact. The neoprene Hoodie fits easily and snugly around your lens hood or shade in either the shooting position or reversed. The Hoodie features a reinforced removable front element protection disc made from rigid plastic and firm foam to further protect your glass from damage. Great for travel and storing your lenses. The XX Large fits lens hoods from 5.5” to 6.25” in diameter.
I measured the head on my GT and its roughly 5.275” so I was thinking I would rather have the larger plastic insert of the XXLarge?
kindle is the Hoodie you have, the XLarge (plastic insert) actually bigger then the GT’s Head?
I’m not inclined to have it fit tight, something to put in the bottom of the bag, that has a plastic protector for the glass that is bigger then the GT’s head. Instead of a piece of fiber board or Lexan/Plastic. Besides it’s only a 1/8’’ bigger on the radius of the GT head at the XXLarge smallest dimension 5.5” so I’m thinking the Hoodie part is still going to be alot smaller? Maybe?
I’ll probably get both playing it safe, use one for when the light is slung over my shoulder on it’s sling and one for the transport bag.
The XXL slips on easily and stays on fine. Think back what the XL fit like on Dales, how it looked snug to the cone of the head. The XXL is not like that. At the cone there is about a 2mm stand-off. The hoodie fits snug (not real snug) to the area that's lens diameter, with a little sag (like loose pants at the waist) over the lens. But it stays on fine. Considering how the XXL fits, and the thought of adding some protection in the lens area, it should tighten the hoodie up some. With the talk of doing this, KB, I may be following your lead. I think I'll use 1/4" high density foam to cover the lens radius, glued to a another that's slightly larger. I'll stop in to see my upholstery buddy tomorrow :D
