My guess is that a new generation of 445nm laser pumped white light diodes will probably come out at some point that increase the luminance by a few 100% there should be not that much of a problem to produce this in a similar package than the LEDs are now
Yes, I agree that lasers can be very small as well, although I don’t think this it too important. They are small enough already. The problem with lasers is that they are less robust and require better cooling compared to LEDs.
I just had the idea that one could seperate the phosphor of an LED from the die by using a piece of short glass fiber. This could result in higher output.
That depends. How hot does the Phosphor get when it is part of a LED? Is it hotter or cooler than the die? Does it heat up more because of the heat emitted by the blue die or by the inefficiency of the conversion process?
At first I dismissed this comment. After all, we BLFers won’t have our own custom LED. But then I started thinking…LED construction may be too hard for us amateurs, but there are quite a few companies which have all the skills and tools. Especially that we don’t need to build everything from scratch. Companies like Cree sell individual dies or phosphors.
Now the question is: what are R&D costs? What are unit costs? What volume would be needed to make this possible?
I have no idea what are the answers to any of these questions. I’d like to have it.
I don’t know. I would imagine that it is unbelieveably expensive.
The LED I mention above would probably need to be made by Luminus or maybe Osram. As far as I know only they offer direct mounted LEDs. Those LEDs are different compared to Cree, Nichia etc.
Theoretically, if the LED has no dome or flat dome they will all have the same spatial distribution following cos(theta)
However I have calculated the lm/mm^2 of many LEDs and it does not match up at all with the measured cd/mm^2 so there is definitely some other variable(s) affecting the intensity.
Real world testing is the most accurate method atm.
I added the new Osram Square Flat. Together with the Luxeon Z ES it’s the only XP-G2 sized LED which comes without a dome. It has a low thermal resistance, only the XP-G2 is even better.
If you list pad size to 3 decimals, your number for Osram Square Flat KW CSLPM2.PC is wrong.
You missed that the thermal pad corners are rounded, so the pad is 2.629 mm².
ADDED:
Also, there’s some controversy regarding Osram Ostar LE UW Q8WP NB, so the listed luminosity may be too high.
You are correct, thanks. I guess I was too lazy for that:)
I agree regarding the fact that there is controversy, but I would prefer actual throw measurements with a reflector to back those values up.
I will also add Köf3’s mneasured values of the Luxeon V.
I know this post is a bit old but I wanted to mention that diamond is 2200W/mk not 3300, and that thermal compounds made of diamond do not actually work very well.
ICdiamond only has ~10w/mk.
The way to get the best thermal connection is to use liquid metal such as coolaboratory liquid ultra/pro or thermal grizzly conductonaut.
The pro and conductonaut have ~76W/mk.
Using this is a better choice than solder because being a liquid it can contact all the small cracks and crevices.
If you tried to solder a copper MCPCB to a copper heatsink it would be almost impossible to get a perfect joint due to the large area and how fast the heat moves away.
High silver content in solder also gives a higher thermal conductivity, about 70-80 IIRC, but it makes pretty much no noticeable difference.
I use 3% silver/tin solder for all of the stuff I do.
Applying and removing the liquid metal is actually really easy to do.
Having an easily removable MCPCB is great, I don’t recommend people solder their MCPCBs to a heatsink.
The LED should never exceed 140C.
If you use liquid metal there is no need to solder anything, that’s the entire point of using it instead of soldering.
If you mean soldering the LED to the MCPCB, you do that before you put the MCPCB on the heatsink and apply thermal compound.
Also if you apply it correctly there is nothing that comes out.
If you overapply and some comes out around the MCPCB you can just wipe it off.
Nothing else from below the MCPCB will come out so it is completely safe.
This is assuming the MCPCB is securely screwed down of course.
I meant using it on the thermal pad of a led while joining electric pads otherwise. If the other joining method is soldering - LM seems off the table. If it’s glueing heat is not a problem.
There was quite a number of people reporting how Conductonaut leaked and caused shorts inside their laptops. That’s why people recommend CLU there - it’s thicker.
I don’t know where he got the number, different places state different things. A range makes more sense to me than a single value. The highest I have read is 2500.
I do find it interesting though that you stated that it doesn’t work that well because this one company can’t or won’t do it that good.
In the end polishing the surfaces will reduce the effect of the paste anyhow. Vinz preferred this stuff especially for potting his lights.
I think it could be used for replacing a DTP pcb. That would be interesting.
Oh I see.
Yeah liquid metal wouldn’t be ideal to use so close to the LED pads.
For stuff like the synios LEDs though the thermal pad is also the cathode so it needs to be soldered anyway.
Using conductonaut between the MCPCB and heatsink is fine, it does not seep out the sides.
I just double checked, the 3300 is for single crystal artificially made synthetic diamonds. Apparently moissanite also has a high thermal conductivity close to diamond.
Still, diamond isn’t fluid so the best that can be done is grinding it into powder and putting it inside another thermal compound.
Due to the surface tension of liquid metal, I doubt it the diamond dust would mix well with that while still allowing good contact between the fluid and solid grains.
This is most likely why the only diamond thermal compounds are regular viscous pastes and not liquid metals.
Instead of having a uniform mixture it has to go mediocre thermal compound -> diamond grain -> mediocre thermal compound -> diamond grain over and over again, which likely leads to the bad performance.
