Thanks for the info! I was hard to navigate/locate post that had the update.
When The Miller gets back, could I have a second unit added? I believe I am number 58 on the list.
Thank you
You are in the interest list nº # 969
Help list for whoever takes over the OP, “The Miller” or “The Team”
Thanks for keeping the list up to date!
Thanks to you
Thank you for this magnificent lantern design that you have given us
Sorry for my bad English
Google translator
Please add my name to the list for one!
Recently brought the Q8 BLF, what a flashlight!
Which one is currently the working design?
Trick question. The answer is: D) None of the above.
It’s being revised.
I’ve been thinking about this light, but design plays a big part in my purchase decisions, guess I’ll wait until it’s more definite
Same, but still watching in case they go back to a more appealing design.
If I remember right, the prototype was the wrong anodising and the plan is to have clear anodising so it will be shiny like the bottom pic.
Yep, Shiny version is the most beautifull one !
I don’t care about design.
I just want it bright and robust.
Is it too late to join the list? If not, please include me
same here, and small size factor, if the lenght keept around same as proto type it would be great if not still nice.
On a normal lamp with contact issues you normaly sand the ends, lube them and you you are fine.
What about this lamp? Sanding one end seems bad.
I guess conductive lube on the ends is also a bad idea. Any lube recommendations?
Or how much fidelity is necessary to troubleshoot and assamble it?
Is it a finicky light?
Major brand lights (Fenix, Acebeam, Klarus) have been using nested tubes like this for a while to enable an e-switch in the tail (usually ill-used for instant strobe) and/or USB charging without turning on the tailswitch. Mine have been trouble-free.
Please add me to the list. Thanks
Post # 2221
Post # 2222
Have you repeated the #Post?
or … Do you really want two units?
