I have not been contacted on how to pay yet…… should I still be waiting or did I miss something?
Doh!……
The next group (3rd batch) to purchase lights (#1050 and up on the list or who signed up after 10/23/17) will get their emails late January to early Feb in order to let Neal get caught up with current orders.
Sorry….I am retarded……watching LEDs turn on, probably isn’t good for my brain…
This reminds me one senior manager once told me he has to spend 4hours everyday just to read and answer emails. Besides quantity is very discouraging, it is also finding correct information part that’s time consuming and might need to confirm with third or fourth persons. Imagine you have to reply all these.
I think this might actually work with a high powered LED light with enough battery capacity and good thermal endurance. The bowl should preferably be matte black to better transfer heat to the bowl and to cause less overheat to the actual light engine. An insulating layer between the edge of bowl and head would have some effect, but I don’t know if this would be beneficial or not.
Let’s not make this too straight forward. This could even work without dismantling the head. Just have a suitable light absorbing thing you want to heat. Not necessarily a bowl, even canned food or a bag that can take the heat(there’s liquid inside when heating, so even a plastic package might survive). Aim the light and insulate package from other directions. Apply until ready to serve.
The latter method would of course only make use of the radiated energy and not the bulk that’s generated in the light itself, but it might be enough.
On second thought, maybe not. Thinking in terms of wattage required to effectively heat food on a hot plate, what’s enough? I think a coffee machine hot plate is in the range of one hundred watts or slightly less, so one would preferably need all the heat from a high powered flashlight, not just the power of the beam… but I don’t know. My intuition is it’s just on the threshold of being usable or not, and I can not decide without experimenting or at least making actual calculations. Even compact lights are pretty good pocket hand warmers but heating up soup - essentially water in sense of thermodynamics - is a way harder task.
I know, the GT is not something most people would take on actual camping trips, but an interesting idea. Just like the idea mentioned earlier in this discussion: it kinda almost floats, but doesn’t. Might not be that close to a density of 1, but closer than pretty much any other flashlight with durable aluminium construction. If it had been upscaled even further, it might float. :partying_face:
Keisari, Kawiboy is pulling 22 amps through his 6V XHP-70, figure the wattage on that little oven why don’t you?
Tomorrow a couple of friends from here are coming up from the coast and we’ll be doing an emitter swap in their GT’s. I have mine and one I bought for a gift so we’ll have 4 GT’s to play with. Plan on getting some photo’s.
Including that tripod adapter for the strap was a really good idea. Earlier I posted about making sure there’s enough depth so it wouldn’t have the problem I have with my Q8. By including the adapter, they bypass the issue. I doubt they caught my comment, so kudos to them for thinking ahead.
Normally 11/2 times the diameter for the depth of thread, 1/4-20 x 1.5= .375” (3/8”) is pretty much a standard minimum of thread engagement unless other wise noted by engineering. At least where I work.
I know DB knows, but for anyone else curious, I’d estimate about 160 “ish” watts. I’m not sure what the voltage sag is, but probably less than a pair of 26650 which tend to pull 17 to 19 amps (with 6v xhp70.2).
I am in the first 555 paid, registered shipping, no batteries to the UK & have not been posting in this thread just patiently waiting
Am I right in thinking that the last of the first 555 DHL shipments have now been made & that next week the first of the non USA non DHL shipments will be sent ?
Thanks Jason as that was why I asked as I have found this thread a little difficult to follow where shipping is concerned.
So most of the first 555 have been shipped ?
Hopefully in the next week or 2 there will be another 2 shipments of around 150 units each which hopefully will start to include the registered shipping ones ?
I am just hoping that mine gets shipped before Chinese new year as registered will mean that it will take about 4 weeks without any hold ups so I am hoping that I might get it by the end of Feb/early March ?
