In the last month, I have spent way too much time learning about the flashlights
I got two Convoy S2+ and an Astrolux S1 and like them a lot. I like the size, interface and output.
Questions:
Looking for a light with less spread and more narrow beam. Definitely want much longer beam range than S1. Is that doable with S1 form factor?
2) If I was to go beyond S1 form factor, I don’t mind larger diameter at the head but want to keep the same length and body diameter. Any recommendations here?
3) Any recommendations for smaller flashlights, say, for keychains?
………good little thread about the above lights w/pictures of all 4 styles………
Things to consider…….
Are you building/moding, or buying “stock” as purchased light ?
- - If you are going with a stock light,
-xp-l hi is about the best stock led for throw in any of these. The Astrolux will probably be your best bet there.
-Power level, the Convoys I linked are all running 2.8A. Not bad, and can run for a good bit on high before getting super hot.
If you want max brightness for short bursts (more power = more heat), a fet driver is the way to go. Again, the Astrolux have them.
-modes, simple or complex user interface? All about personal preference here.
- - If you can/dont mind soldering 2 wires on the led “star”, buy any of the lights above as host, then add…
one of these…
- xp-l hi is a good general purpose, off the shelf “throw” led.
de-domed xp-g2 (MTN has these, just check the de-dome option) is still the best 3V (single battery) thrower led IMHO. It does lag behind the xp-l hi in overall lumens though, and requires higher forward voltage.
or if you are going to run a fet, and just want short bursts…
-SST 40 or Luxeon V. On a fet driver, they can hit over 2000 lumens pretty easy. +Not as throwy as the above 2, but might make up for it with pure power.
And a driver, all are 17mm I believe, and choices are many
-fet drivers are for max power, short run “bursts” These will put out the most lumens, and throw, but you will not be able to run them on max for more than a minute or 2 before they are melting your hand.
3A regulated drivers are also plentiful. Good output, and any of the above hosts should be able to handle running at this power level for a good length of time.
Then there are the hybrids, w/regulation up to a certain point, and FET for “turbo” modes.
like TA drivers from Lexel here on BLF (Have a couple, w/more on the way including my first 1S version)
or H17F from MTN (my personal favorite single cell driver for now due to the UI. Options for EVERYTHING)
A lot to consider.
Any questions, just ask. We are a helpful bunch around here.
Had to add……….
As mentioned, the Emisar D1 is a good light from what I have seen here.
Still a new one to me, I keep forgetting about it.
In the C8 form factor, Sofirn also deserves a look. The C8A (which I have) puts out a lot of light with a useful mix of spill and throw, the C9T, with and XP-L HI doesn’t put out as much light, but what it does put out looks much more concentrated for throw. The C8F triple makes lots and lots of light.
You could try a TIR optic in a Convoy S2. They are available in a variety of beam angles to fit the S2. I haven’t tried them myself but Lightbringer has had experience with them and seems to recommend them, maybe PM him to chip into this thread if you are interested?
The Convoy C8 is great as a thrower, I can certainly recommend that but the head size is maybe more than you want.
Just catching up on the posts. Very informative and thx for breaking it down for me.
How about putting an XHP in a BLF A6 host? Seems like many of the EDCs from major brands that claim over 2k lumens and high throw are using XHP.
someone correct me if I’m wrong but, I believe XHP LEDs require a higher voltage meaning you need more batteries in series or a boost driver.
If I were you my next purchase would be a Convoy C8. They come with good throw out of the box if you choose an XPL HI version. Also, they are super easy to mod. I
have a C8 with an SST40 LED and BLF X5/X6 driver and it is pushing close to 2000 lumens and due to reflector size it has some serious throw.
