Trick question. The answer is: D) None of the above.
It’s being revised.
I’ve been thinking about this light, but design plays a big part in my purchase decisions, guess I’ll wait until it’s more definite
Same, but still watching in case they go back to a more appealing design.
If I remember right, the prototype was the wrong anodising and the plan is to have clear anodising so it will be shiny like the bottom pic.
Yep, Shiny version is the most beautifull one !
I don’t care about design.
I just want it bright and robust.
Is it too late to join the list? If not, please include me
same here, and small size factor, if the lenght keept around same as proto type it would be great if not still nice.
On a normal lamp with contact issues you normaly sand the ends, lube them and you you are fine.
What about this lamp? Sanding one end seems bad.
I guess conductive lube on the ends is also a bad idea. Any lube recommendations?
Or how much fidelity is necessary to troubleshoot and assamble it?
Is it a finicky light?
Major brand lights (Fenix, Acebeam, Klarus) have been using nested tubes like this for a while to enable an e-switch in the tail (usually ill-used for instant strobe) and/or USB charging without turning on the tailswitch. Mine have been trouble-free.
Please add me to the list. Thanks
Post # 2221
Post # 2222
Have you repeated the #Post?
or … Do you really want two units?
Just one, it seems to be a mistke. Thanks a lot
Wow mixing the Nichia 219c tints would be so awesome! I would love to see that in action and would be nice if we have the option to add money for custom features similar to how the Emisar D4s are sold.
I don’t expect tint-mixing to happen. It’s not really in the Overton window yet, and it would mean tripling Lumintop’s investment. Instead of a single reel of 3000 emitters (1000 lights), it would mean committing to three reels of 3000 each, or 3000 total lights.
Even if Lumintop wanted to make three times as many units, they’d probably just offer it in three different flavors.
You could create a ‘Team account’, as was done in the BLT GT thread; and ask sb to change the original post ownership from the miller to the ‘Team account’. That way the OP (original post) could be updated with the needed information.
It worked well in the GT thread once it was done.
I’m in for two
Please count me in for 1. Thanks.
I guess you should be “promoted” to a team member!!!
Thanks for the work done so far pepinfaxera :+1:
