ThruNite TC20 (Compact XHP 70.2) / Full review
95 posts / 0 new
robo819
robo819's picture
Last seen: 3 weeks 14 hours ago
This is the ThruNite TC20 flashlight , sent to me for review by ThruNite and NO other compensation other than me keeping the light.
There is a 20% discount until January 31st using code TC20 on the main site……..
http://www.thrunite.com/thrunite-tc20-3800-lumen-flashlight/
Light can also be found on Amazon……….
https://www.amazon.com/ThruNite-Rechargeable-Tactical-Flashlight-Capacit... (both links are NON affiliated)
The TC20 arrived in an Amazon box with large bubble wrap and the ThruNite box inside that. Everything was well packaged and the Thrunite box and contents in perfect condition when I received the light.
As I have come to expect with the ThruNite products the TC20 just made me think quality as soon as I pulled it from the box. A very compact , yet robust feeling light as soon as it is in hand.
The package includes the TC20 itself , 5000 mAh Thrunite protected cell , Nylon holster , extra O-rings and USB charging port cover , the charging cord , as well as the silicone piece that goes under the switch (incase it ever wears out) instruction manual and thank you card. The light is a very compact , single 26650 , and one of the smallest I know of out there in the form factor of XHP 70.2 and the single 26650 cell.
Left to right —— Thorfire VG10 / TC20 / Eagle Eye X6
On the outside of the light as mentioned , everything about it just says quality. The knurling is very well done and very grippy , the Anodizing is near flawless , bezel is well made and machined and the overall finish is just great.
The OP reflector is a heavy aluminum one with just about the right amount of texture to it (for my liking at least) and it is also machined very well. The reflector sits behind an AR coated lens that was almost invisible when I first took the light from the box.
The Side Switch is a very nice metallic switch and is the only switch on the light , controlling all functions. There is a light in the center of the switch that is an indicator and it comes on when the light is powered on , other than in the moon mode , with a blue light showing. The lighted switch also serves as a Low Voltage indicator and will turn Red when the cell starts nearing depletion. The same switch light is a charging indicator as well and shows Red when charging and then turns Blue once the cell is fully charged , using the USB charging port. If the cell is placed in the light reversed , or if there is another problem with the cell inserted , the indicator light will be blinking and show Purple to let you know something is wrong, or “improper charging”. The USB charging port is located on the opposite side of the switch and seems to be pretty well sealed when the rubber boot is properly in place. The listed amperage on the side charging port is 2 Amps , but I have not tested that.
The UI is a pretty simple one and has pretty good spacing between the modes to suite me. A long press from off will get the Moon mode , a press of about 1/2 second takes you to each “next” level of Low / Medium / High and then a quick double click gets you to the Turbo mode. The strobe is accessed with another quick double click from the Turbo. You can get the Turbo mode also from any other mode , including off and a quick click of the switch turns the light on or off. There is mode memory for the Low , Medium and High modes.
The tailcap springs (yes 2 of them) are 1 smaller spring in the center of the board as we are used to seeing and the other spring is a heavier gauge wire and much bigger in diameter. The Larger spring is a little less stiff than the center spring , so it allows the larger spring to compress easy when the tailcap is screwed down so that both of the springs are making contact and therefore helping carry the current without need for a spring bypass.
The threads on both ends of the tube and also the head and tailcap are all very well machined and square cut and all were lightly lubed.
The XHP 70.2 emitter sits perfectly in the middle of the large opening of the reflector and the MCPCB is screwed down to the shelf with 2 small screws. The smallish sized light handles the heat better than I thought it would from the XHP 70.2 emitter making all those lumens also. It does get hot by the time the light steps down , but not like instant blister you hot if you touch the head. The beam from the TC20 is a good mixture of throw and flood both , giving a very wide coverage area for such a small light and reflector , but at the same time it will put good light well downrange also.
AT 100 yards on High and Turbo / also at 50 yards Medium / High / Turbo
The charts on the Lumens and amperage testing I did with the TC20 ……….
The driver , best I can tell , is a Boost driver with constant current.
I have not gotten the driver out of the light yet as it seems to be either well glued or press fitted very tightly , I may revisit that at a later time. If I do decide to get the driver out of the light later I will update this thread at that time.
I personally am very pleased with the TC20 in the fit, finish , feel and overall performance of the light.
For those who may not want to see the whole video , but would like to see the outdoor “Live Footage” and comparison , The rest of the still shots of the light and beamshots start at 9:48 of the video timeline and the outdoor footage starts at 13:25 of the timeline.
Video Followed by listed specs………….
Specifications
•LED: CREE XHP 70 2nd gen. with a lifespan of 20+ years of run time.
•Compatible with: 1 × 26650 (ThruNite 26650 5000mAh).
•Reflector: Orange peel reflector.
•Working Voltage: 2.75 – 4.2 V.
•Output mode/Runtime:
-Turbo (3800 lumen; 130 minutes)
-High (1800 lumen; 145 minutes)
-Medium (320 lumen; 10.2 hrs)
-Low (38 lumen; 46 hrs)
-Firefly (0.5 lumen; 37 days)
-Strobe (2280 lumen; 180 minutes)
•Peak Beam Intensity: 25580 cd. (max).
•Max beam distance: 320m (max).
•Impact resistant: 1.5 meters.
•Waterproof to IPX-8 Standard (2meters).
•Weight: 148g without battery. .
•Dimensions: 119mm in length x 42mm in head diameter x 33.5mm in tailcap diameter.
•Accessories: Holster x1, Spare O-rings x2, Lanyard x1, ThruNite 26650 battery x1, USB Charging Cord x1, Spare USB plug x1, Spare Side Switch cap x1
•Turn ON/OFF
Single click the switch to turn the light on and off.
•To Change Modes:
When the light is on, long press the side switch to cycle through low, medium and high.
Shortcut to firefly: When the light is off, long press the side switch to get firefly mode.
Double click to turn to turbo from any mode. Another double click to get strobe.
•Memory Function:
The light will turn on in the last mode accessed, except firefly, turbo and strobe.
•Rechargeable Function:
2A charging by USB port. During charging, the indicator is RED. After being fully charged, the indicator will be BLUE.
When indicator flashes purple, it means abnormal charging. Only firefly, low and medium modes are available while charging.
Click any link to see MY REVIEWS:
Maxtoch M24 Sniper / Maxtoch 2X Shooter (2016 factory dedomed) , 2X - XHP 70.2 / Maxtoch Xsword / M1 Archer *** ### ThruNite // Archer 2A V3 / Ti4T / TN4A HI / TH10 / TH20 / C2 Mini / TC12 V2 / T01 /  , neutron 2C V3 , TC20 / Catapult V6 / TC15 / TC15 CE *** ###  Olight // H2R Nova , S10R III / S30R III / H1 Nova / H1 R Nova / X7 Marauder , PL Mini ,  M2R warrior //// Orca T11 / Nitecore EC20 / BLF A6 / Custom Convoy C8 / Lixada Triple 3800LM / Lixada 1000LM / LuxStone X30 / Manker E02 / Manker E14 II /  ### Thorfire /// PF03PF04 , Upgraded PF04 , C8 , S-50 ,  VG-10 , VG25 , C8s , BL30 , TK4A  , S1 , VG15 S  , TK 18 //// ##WowTac// A4 , A1 (original) , A2 headlamp , A3 //// Acebeam L16 /// Massdrop (Lumintop) Brass EDC
Edited by: robo819 on 05/02/2018 - 11:38
Franz
Last seen: 1 month 5 days ago
Ow God, this thing is smaller than vg10 Shocked
Good review Robo, the spill seems huge. May you compare to another light like vg10 the beam angle? Blushing
This light is very expensive to edc unfortunately, thats the only thing which dont turns it perfect Crying
robo819
robo819's picture
Thanks franz…..
Yes it is very compact to have the XHP 70.2 and the kind of coverage area it does.
Unfortunately all 3 of the VG10’s I have are modded out with either dedomed emitters or XPL-HI in them , but I went ahead and got a shot of the one with the HI in it that is pictured in the review . as well as the Olight X7 Maruader with the triple XHP-70 emitters in it to show the beam profile.
VG10
TC20
X7
Franz
Thanks Robo, the spill seems more wider than L6/S70, great light Thumbs Up
In thrunite store they cant shipping to brazil and amazon request pre-paid taxes (which doubles the price Facepalm ), the last store I can find this light is hkequipment but they dont have that 20% discount code Crying
robo819
robo819's picture
Sorry to hear that…maybe they will work on getting world wide shipping in place for their products soon.
I just compared the beam also to the L6 and the S70 , it is a little wider than both of those.
Franz
Thanks Robo for compare them, the diameter of spill for me is essential for chose a light Thumbs Up
SKV89
Last seen: 1 hour 26 min ago
Thanks Robo for the great review. I’ve been waiting for someone to review this flashlight for awhile. The beamshot angle was especially useful. I was actually hoping the light would be wider angle with more flood than it is. I was debating to either get this light or the much larger Haikelite M09R. I’m thinking I will go with the M09R as it seems floodier.
robo819
robo819's picture
Always glad to do the reviews.
I am not familiar with the M09R but the little TC20 does have a pretty good coverage area , especially for the compact size it is.
If you can go to the video and watch beginning at 13:25 you can see just how well the small light compares in coverage to the much larger Olight X7 with the triple XHP 70 emitters and that one makes a wall of light.
Gerrit
Last seen: 10 hours 41 min ago
Nice review David Thumbs Up
too bad there is no group buy.
robo819
robo819's picture
Thanks….
Not sure I have ever even seen ThruNite do a GB though.
Of course I have been wrong and forgetful before too…….lol
beam0
beam0's picture
Last seen: 3 months 2 days ago
Thanks for the review and video, I was waiting for this here and also on YT.
I really enjoyed watching it on my 50” TV relaxing on the couch! Again I loved the “Rock out” slideshow segment!
Also a very helpful photo right here, the X6 is enormous!!
robo819
robo819's picture
The Olight R50 pro looked slightly brighter to me, also interesting the TC20 has a colder tint than the R50 pro.
!{width:55%}https://s20.postimg.cc/kgnolz6pp/DSC03070.jpg!
You’re welcome and Glad you enjoyed the review.
It was the Olight X7 Marauder I used to compare though and I went to the Turbo 1 setting with the X7 which is around 5500 lumens compared to the TC20 at around 3500 lumens at that point.
As far as the tint they are pretty close really in person but the X7 has a much larger head and uses 3 XHP 70 emitters with a broader beam area , compared to the single XHP 70.2 in the TC20.
I wish I had a closer comparison but the TC20 just doesn’t have the same beam as any of my other 120 or so lights I have in there believe it or not. All the others are either more floody or more throwy in comparison with most of them being more throwy , other than the X7.
Just to give a little better perspective just how small the TC20 is , here are the X6 and the TC20 laying across my hand side by side.
beam0
beam0's picture
Wow it sure is small! Thanks for correcting me sorry about the Olight, I got that part confused with a different review, (previous post edited)
specialk
Last seen: 6 days 23 hours ago
Will a 67.55mm flattop battery work in the TC20?
Newlumen
Newlumen's picture
Last seen: 6 months 4 weeks ago
Hi robo, can you compare a photo between tc20 and wowtac a3. Thanks.
robo819
robo819's picture
Left to right ….A3S / (Head Extended) , TC20 , Thorfire VG10
hIKARInoob
hIKARInoob's picture
Last seen: 4 days 6 hours ago
What a stunner. And super compact. Looks like this light is definitely MVP material. But why on earth the generic bland name “TC20”? This light deserves a much cooler name. Cool
robo819
robo819's picture
The shorter cells will work , However I did notice with the flattop unprotected cells I tried , good bump of the tail end or head end will cause a quick flicker.
If you do not jar the light hard they work fine though.
robo819
robo819's picture
I quit questioning the names they give a lot of these lights and accessories a long time ago , as some of them get really weird.
Better TC20 than Short Bright or something like that though……lol
beam0
beam0's picture
The included Thrunite button top is 69.4mm (including the button)
  • 67.85 Flat top Xtar 5000mAh (protected) works
  • 65.30 Flat top LiitoKala 5000mAh (unprotected) also works
So your cell will work
My light flickers with a good bump even with the included Thrunite button top cell.
beam0
beam0's picture
Yeah, they should’ve called it the Mk2 Evil
beam0
beam0's picture
Thanks for posting this photo, I didn’t know about the A3S before I saw this, I’m highly interested, think I’d like to try that one.
Newlumen
Newlumen's picture
Thanks. Tc20 look compact.
Nuclear
TC20 coupon still working
Just ordered one
Thank you for review
robo819
robo819's picture
Nuclear wrote:
TC20 coupon still working Just ordered one Thank you for review
Hmmmm……..They extended the sale I guess?
Nuclear
May be….
Iwas a little bit glad Cash
charles lin
charles lin's picture
Last seen: 1 day 4 hours ago
No need to hurry, Plenty of time!
SKV89
I guess the extended the sale to compete with Acebeam EC50 III
robo819
robo819's picture
The TC20 is already $46 less than the EC50 Gen II or Gen III , with both at regular price.
With 20% off , or an extra $17 off , the TC20 is hands down the best choice in my opinion , since they are both about equal in size , output and performance.
Newlumen
Newlumen's picture
I forgot to mention i received my tc20 in cool white.. its a very good light and Would even consider as a EDC light for me. Thrunite are very reliable and user interface is awesome.. just the way i want it.
I wish thrunite use 26650 in their tactical light.
hIKARInoob
I’ve always felt $100+ on a single XHP50/70 light with boost driver (single cell) is completely bonkers, no matter how premium a brand is. Thrunite’s pricing makes the TC20 a much more lovable light to me.
