The little lantern mod (part I+part II), finished
28 posts / 0 new
djozz
djozz's picture
Last seen: 3 hours 44 min ago
I wanted to make a small lantern based on the Utorch UT01, with a campfire/candle colour temperature (2200K). There are not many leds in that colour temperature, I know that the Nichia E21 comes in that tint but Clemence does not have it (yet).
So I came across this über-obscure led at RS-online, the Stanley Electric GSPW1651NSE-20Y-TR Party . It is a 5050-size japanese mini-COB led with 6 parallel midpower leds in one tiny LES (datasheet). Rated at max 600mA, 85CRI and just 81 lm/W this led will not win any performance contest. But it is 2000K!, that should create some cuddly atmosphere.
I did a quick voltage/output test on one of my 119-boards to see if it would survive the 600-ish mA that the Utorch UT01 provides on an Eneloop.
So the led is ok at least up to 1250mA and should be fine in the Utorch and give a bit under 100 lumen OTF, which is fine for a lantern.
So it was soldered into the UT01 (after the board was sanded down to 13.5mm diameter). To fit the larger than stock led under the reflector the centering piece was left out and the corners of the led filed off a bit with a small diamond file. It all worked and indeed very warm the tint is! Shocked , almost as orange as a PC-amber led, but unlike the amber led there is some of the blue side of the colour spectrum leftover, the tint is just extremely warm.
A peek into the reflector shows the six distinct leds. Of course that affects the beam, a royal donut hole is the result. But it will be a lantern so that is no problem.
I get 88 lumen on the highest setting, and 0.8 lumen on the lowest, a good range for the lantern.
Part II will be the lantern conversion, when I have time to finish it I will post about it.
_____________________________________________
Part II, the lantern conversion.
This part was intended to look a bit more professional, but the used techniques were a first for me, it was not as easy to get it slick looking.
First I bought a rod of 15mm diameter solid acrylic, that fits almost tight through the bezel of the UT01. A piece of it was cut off, first a 2.5mm hole was drilled in the top, then with a countersink drill a conical hole was drilled. The deepest part of the 2.5mm hole was M3-tapped. A conus was bent from a piece of aluminium foil. And a 16.5mm diameter replacement lens was made from a sheet of acrylic (it looks blue because of the protecting foil).
The plastic on the inside of the conus was liquified partly with a cotton-swab drenched in chloroform, then the aluminium foil was rubbed in place using the swab.
The tail-side of a two-pence coin was filed flat (I would not do that to the queen) and three holes were drilled in it (one through her ear, I reckoned I would get away with that), a hex-screw was used to screw it on top of the optic. The acrylic was sawed to the correct height.
The 16.5mm acrylic lens was glued on the underside of the optic with chloroform, not crystal-clear unfortunately but it will do the job fine. Here it is shown with the bezel already around it.
And here’s the finished light. I painted the coin with matt black heater paint, that did not cover her majesty 100% but it is kind of fun that you can still see that it is a coin.
And the beam is pretty nice, mainly going sideways in all directions. The output is 51 lumen on max, while out of the reflector without the optic on top came 94 lumen. So the optic caused 45% light loss, a manufacturer should be able to improve on that Wink
I’m happy with the result, as said less perfect looking than intended, but it is a nice little tent lantern that will certainly make me very happy during my camping trips Smile
Edited by: djozz on 12/27/2017 - 18:53
MRsDNF
MRsDNF's picture
Last seen: 22 hours 33 min ago
Very nice mod djozz. Just need a shot of a bottle of wine with you light shining on it. Smile
djozz
djozz's picture
Thanks, right, here’s the proper beamshot:
goshdogit
goshdogit's picture
Last seen: 11 hours 35 min ago
Very nice!
You’ve got me wanting a very warm Eneloop-powered ‘mood light’ now…
edeekeos
edeekeos's picture
Last seen: 1 year 1 month ago
that is stunning! such a warm tint!
DavidEF
DavidEF's picture
Last seen: 2 days 14 hours ago
Nice! Even though I don’t particularly like very warm tints in real life. Silly
- The YKK Philosophy
MRsDNF
MRsDNF's picture
!{width:40%}https://farm5.staticflickr.com/4484/37740897921_7c5a8298b3_c.jpg!
Perfect. Now how do I get my darling wife to be romantic? Love
DBSAR
DBSAR's picture
Last seen: 4 hours 3 min ago
Nice mod Smile i have a few micro LEDs in that tint range of flame of a candle, but they are to small for in a flashlight host.
CRX
CRX's picture
Last seen: 6 hours 48 min ago
Should be cool Thumbs Up
Ice
Nice light to get your girl in the mood . Sadly not enough light to find her
Jack Kellar
Jack Kellar's picture
Last seen: 3 hours 57 min ago
I don’t know what’s the better vintage, the wine or the lighting.
FPV
FPV's picture
Last seen: 10 months 2 days ago
really nice tint, perfect for fall and Halloween. I often wonder how creative some users are with sourcing exotic LEDs Smile
interesting mod and I am looking forward to seeing the lantern.
dekozn
Last seen: 2 days 51 min ago
It looks real warm (was gonna say cool but….)
But I gotta ask, if you want a real warm yellow collor why not go for an amber colored? I’m just curious…
Idiot proofing something only creates improved idiots.
Jack Kellar
Because of the CRI. Low-pressure sodium gas lamps are way warm but their tint is AWFUL, because they have atrocious CRI.
djozz
djozz's picture
Yes, I have a flashlight with a PC-amber led in it, which already has a wider spectrum as a normal amber led, but still the blue region is completely absent. This led still has some blue in it so blue colours do appear a bit blue instead of grey.
giorgoskok
giorgoskok's picture
Last seen: 1 month 1 week ago
Nice work Djozz !
About the donut hole , could it be from the wrong focus of the reflector ? I could be totally wrong …
Beachlogger
Last seen: 2 weeks 4 days ago
Nice, now you just need to make it flicker and you’ll have a nice campfire
clemence
clemence's picture
Last seen: 4 hours 26 min ago
Cuddling afterwards….
-X3-
-X3-'s picture
Last seen: 22 hours 8 min ago
As a French person, I’m irritated by that screw-on cap on a bottle of wine… but I DO enjoy the scenery Smile
Nice lantern ! I love my 219C 2700K for ambient lighting !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
-X3-
-X3-'s picture
FireFlyMod wrote:
X3 wrote:
As a French person, I’m irritated by that screw-on cap on a bottle of wine… but I DO enjoy the scenery Smile Nice lantern ! I love my 219C 2700K for ambient lighting !
Bah… C’est plus une affaire d’esthétisme…undecided
Finalement, si tu réfléchis bien, le bouchon à viser est techniquement meilleur que liège.
La 219C est excellente! +1
Faut bien défendre les traditions, “on a toujours fait comme ça” Party
30 ans et déjà réac’, ça promet !
djozz
djozz's picture
Next time I will picture a wine bottle with a cork! Smile
I finished the lantern, see the OP.
clemence
clemence's picture
“…drenched in chloroform….” Sick
Did you fell asleep in the process?
Nice idea, I’ll make my lantern soon. We have the 2000K now.
- Clemence
djozz
djozz's picture
I did the choroform work outside on the balcony Smile
Yes, I would have used your 2000K E21A if it had been available when I did the led swap, it is probably more efficient too. Please post about your lantern when you are making it!
chops728
Last seen: 3 hours 50 min ago
Perfect. Now how do I get my darling wife to be romantic? :LOVE:[/quote]
I advise leaving Flashlights out of the equation————— Smile
Boaz
Boaz's picture
Last seen: 10 hours 8 min ago
[/quote]How do I get my darling wife to be romantic?
Chloroform
MRsDNF
MRsDNF's picture
Chloroform
Do you know where I can get this in bulk? Facepalm
ARsee
ARsee's picture
Last seen: 3 weeks 5 days ago
Chloroform
I had chocolate milk running from my nose, reading that response
Agro
Agro's picture
Last seen: 27 sec ago
MRsDNF wrote:
Chloroform
You have so many wives?
