♥ Niwalker 2018 Group Buy! (rare opportunity) /// BK-FA30S / MM18JR(70.2) / MM18III/ C11(XP-L2) - 【 ACTIVE 】
410 posts / 0 new
freeme
freeme's picture
Last seen: 20 min 31 sec ago
 Niwalker 2018 Group Buy is ACTIVE now. Reply below if you wish to receive our deal details.
Product review: LEXEL / Maukka
MSRP: $159.95 / GB price: $LOW
Features
  • Utilizes U.S. made Cree XHP35 HI emitter
  • Maximum output up to 2200 ANSI lumens
  • Highly efficient constant current design offers maximum output and runtime
  • Smart triple Multi-function clicky side switches.
  • Memory function to remember last output setting used (except hidden modes on main switch)
  • Advanced thermal protection circuit prevents overheating
  • Unique smooth reflector design provides great throw beam distance and beam pattern
  • Aircraft grade aluminum, mil-spec hard anodized for maximum wear
  • Toughened ultra-clear tempered glass lens with anti-reflective coating
  • Large cooper heat sink pad for superior thermal conductivity
  • LED indicator turns red(below 12V) to alert user to switch lower output mode and recharge batteries in time
User Interface
  • Press hold the main switch for momentary activation (100% output). Do second -press hold within 3 seconds for 100% constant on.
  • Double click the switch for instant strobe.
  • Triple click the main switch for lock out.
  • Press hold the main switch when light is on for changing outputs (0.2 lumen>25 lumen>300 lumen>900 lumen>1500lumen).
  • Once you release the switch, the light comes on constant output with mode memory.
  • When the light is on-double click to access hidden modes (SOS, beacon, warning flash).
  • Press hold the switch for changing hidden modes.(light flashes to let user know you are in next mode). One click gets you back to the output you were in.
  • You can save one different mode or output on each switch next to main switch. (Press hold the switch that you want to save - led indicator on main switch flashes means its saved.
  • All three switches are able to operate independently when modes/outputs are saved.
Product review: Maukka
MSRP: $229.95 / GB price: $LOW
Features
  • Utilizes total 3 U.S. made emitters - 2xXHP70.2+1xXHP35 HI
  • Maximum output up to 10,000 ANSI lumens
  • Memory function to remember last output setting used (except main switch)
  • LED indicator turns red (below 12V) to alert user to switch lower output mode and recharge batteries in time
User Interface
  • Press hold the main switch for momentary activation (100% Output). Do second press hold within 3 seconds for 100% output constant on.
  • Double click the main switch for strobe.
  • Triple click for lock out (main switch, switch A and B)
  • There are three settings in main switch- setting 1 (2xXHP70.5) > setting 2 (1xXHP35 HI) > setting 3 (2 x XHP70.5 x 2 + 1xXHP35 HI). You may select your desired setting first and then press hold the main switch when light is on for changing outputs
  • When the light is on - double click to access hidden modes (SOS, warning flash, beacon)
  • Press hold the main switch for changing hidden modes.(light fast flashes to let user know you are in next mode)
  • You can save one different mode or output on switch A or B (Press hold switch A or B that you want save)
Product review:
AdventureSportFlashlights
MSRP: $259.95 / GB price: $LOW
Express Your Interest Below
Edited by: freeme on 09/13/2018 - 14:24
freeme
freeme's picture
My VOSTRO order is here. cool
shakeym
shakeym's picture
Last seen: 1 week 3 days ago
Count me in,,,,
casi29061965
Last seen: 5 hours 5 min ago
Interested, depending on price !
arficus
Last seen: 4 months 4 days ago
yes
FlashMax
FlashMax's picture
Last seen: 5 days 6 hours ago
Yes
Max
southland
southland's picture
Last seen: 1 day 22 hours ago
Vostro
freeme
freeme's picture
I have included MM18III in the list. Just reply which model you guys are interested with.
casi29061965
Interested may be for all three, depending on price.
uncle_muscle98
Last seen: 3 months 3 days ago
I am interested in all 3
FlashMax
FlashMax's picture
BK-FA30S
MM18JR 70.2
Depending on price of course
Max
Box
Last seen: 1 month 12 hours ago
MM18JR(70.2) And MM18III
surasakkongtha
Last seen: 6 days 14 hours ago
interested
square74
Last seen: 13 hours 52 min ago
Hi,
thanks,
depends on price of course,
Vostro.
san san
Last seen: 3 weeks 5 days ago
hi
interested 1* #1,#2,#3
Thanks
Andybibbville
Andybibbville's picture
Last seen: 1 day 4 hours ago
MM18JR 70.2
John 12:46 “I have come into the world as a light, so that no one who believes in me should stay in darkness.” Genesis 1:3 And God said, “Let there be light,” and there was light.
stealth006
Last seen: 8 months 8 hours ago
longtime lurker here, interested in all 3
Mstevens113
Mstevens113's picture
Last seen: 8 hours 46 min ago
Interested in the FA30S if the price is right.
southland
southland's picture
All three now pending price.
schatti
Last seen: 6 months 6 days ago
BK-FA30S
Greetings
ARsee
ARsee's picture
Last seen: 1 week 6 days ago
I had interest in the BK-FA30S.
Lexel reviewed the light extensively, with a nice (thorough) review and tear-down! Thank you, Lexel Smile
There are too many issues Niwalker needs to fix.
Niwalker does not want to disassemble-fix-reassemble? My guess, a group buy to get rid of them. More cost effective for them.
I want a light that's perfect right out of the box. Not a light that needs modded to make it what it was suppose to be
No thanks. Maybe after they fix and re-release.
Edit
I spoke with Lexel about the updates he plans and changed my mind.
I purchased elsewhere
arficus
Ditto above, and lack of NW/WW is a deal breaker.
square74
BK-FA30S with LED from BLF GT would be nice for me, too… Wink
freeme
freeme's picture
Light will be in stock form. If capable of DIY, you may want to consult Lexel for upgrade options.
square74 wrote:
BK-FA30S with LED from BLF GT would be nice for me, too... ;)
Bruno28
Last seen: 4 days 14 hours ago
im in for all three if well priced. I like Niwalker. they are well made
Tender
Interested in all three, but depending on price
"Keep On Luxing" © and "May The Lumin Be With You" © (by my very self)
PBWilson
Last seen: 4 hours 29 min ago
Interested mostly in #2 and #3.
Nicolicous
Nicolicous's picture
Last seen: 48 min 23 sec ago
interest 1) BK-FA30S depending on price
Hardware
Hardware's picture
Interested 3) MM18III, depending on price
suratyu
BK-FA30S depending price
Thank
freeme
freeme's picture
Group buy will start as earlier as next month at jaw-dropping price!!! coolcoolcool
