Got today the 2. batch boards along with more light types, was some delay from DHL because the content was just described as “boards” so they did not how to declare for import taxes
I am very happy with the quality of the boards better than last Chineese manufactory I ordered and cheaper too, multiple sizes of stencils cheap too
Especially the silkscreen is way better than last one that did not supported such small letter size which messed it up
Lexel, bare with me. I’m out of my realm of knowledge.
I see you have boards for the TN42. What (over stock) are the advantages gained by using your configurations?
It’s mainly the different UI. NarsilM with ramping, blinking out battery voltage, etc… It is usually way better than the stock UI’s.
You can also adjust the power output if you want. Up to 3A at 12v. If the stock light only had 2A for instance, you could bump it up a little to 2.5A and get a bit more output.
2.5A GT makes a bump from 663 to 707kcd on a TN42 I modded
current over 2.5A makes no sense, 2.7-2.8 on a good cooler there may be a few % gain in throw but also this mainly starts getting the LED to turn over to get blue very quick
Main advantage is the UI you can change so many things like you want the UI for your purpose
It sounds like the UI of the GT, which I like.
Assuming the board is plug/play, are the boards, electronics better quality? What type of output gain (reach/throw?) is .5A going to give?
