well! guess who was stupid enough to put BOTH carriers in backwards. damn lucky i hadn’t intended to fire her up only because someone recommended evaporating excess thermal grease and i haven’t got the vises to open it up yet… else BLF would have lost one member… at least i’d have gone happily if only for a few seconds lol
The wife hasn’t collected it from the neighbor yet so I can only guess that the TNT delivery today was the GT. I’ve not ordered anything else so it is highly likely. I’ll confirm in ~4hours but i’m 99% certain it is.
Congrats! Good news. $25 is under the €22 Why on earth puts Lumintop $30 on my packet? Neal wrote me before shipping it's $25 With 30 invoice you have no change to slip through customs.
Almost all of the prototype lights suffered a piece of the centering ring being scraped off and landing on the LED and caused it to burn.
It looks like to fix this they decided to center the reflector to the mcpcb instead of the LED itself. Which is a good idea and something we considered when this started.
This works fine in the vast majority of cases but in some the LED will reflow slightly off-center and cause an issue like you saw. The good news is that yours is about as bad as it can get and sometimes reassembling the light can fix it like it did in your case. It also should not be enough to make any noticeable difference in the throw of the light.
Seeing as the LED burning would kill the light, I would say this is a worthwhile tradeoff to make sure that doesn’t happen and completely kill the light.
Not to worry, nothing to do with the light itself.
Also, there would be no need to file a paypal dispute, you can simply request a refund at any time before it ships and we will be happy to send a full refund.
It is not an issue. It is by design. The carriers must be pressed against the driver in order to complete the connection, so there is some extra thread depth to make sure that can always happen.
The black centering piece is machined from Delrin, oddly enough it isn’t perfectly symmetrical… if it’s touching the emitter it needs to be flipped around. All 4 that I have seen this has been true on.
