I guess you should be āpromotedā to a team member!!!
Thanks for the work done so far pepinfaxera :+1:
Agreed! Thanks pepinfaxera :+1:
MascaratumB and Jiffy : Thank you
. Not being able to be a member of the team
I help what I can.
I ignore (not speak) (not understand) English language
Google translator
Pero, estas haciendo un trabajo muy bueno y de gran valor para lo seguimiento de este proyecto Gracias!!
(But, you are making a very good and valuable work to follow this project! Thank you!)
Put me down for one plz
In for (2)!
EDIT: Letās make it an even (2)ā¦ hehe
Iāll take one as wellā¦Thanks BLF and all whoāve worked on this design !!!
I am interested.
Forgive me for not going through 75 pages of messages, is there a lumen output approx. on this light? And any idea how long until completion?
Output of FET triples is pretty well established and tends to be between 2000 and 3500 lumens depending on emitters. Last I checked a 219C (90 CRI D240 flux) FET triple, it was about 2500. A low-CRI XP-G3 (or low-CRI 219C for that matter) would be higher.
I made some progress on the firmwareā¦
Candle mode is updated and more realistic now, simulated using six oscillators ā three of which modulate the other three like an old analog synthesizer. The result looks similar to a candle with periodic disturbances in the air.
Fixed a bug in thermal regulation and LVP, which were both running about 1000X faster than intended. So, those work again.
Thermal regulation uses 512 internal steps while searching for a sustainable level, which makes the adjustments invisible by eye. A lux meter is needed to see what itās doing.
Made thermal adjustment speed change depending on how far it needs to go. It can happen anywhere from 1 step every 8 seconds to 8 steps per second.
Added the ability to calibrate the thermal sensor to room temperature. This should help with the issues related to different attiny85 units disagreeing on how warm it is.
The UI diagram is updated too:
Very sweet ToyKeeper! Thank you!
Nice TK!! :+1: ā¦ Thank you.
Iām in for a single FW3A.
Iām down for 2. Thanks
Oh, I forgotā¦ I also made lockoutās moon mode use the current ramp floor. Previously it used whichever floor was lower. So, the momentary illumination in lockout mode can effectively have two settings depending on which ramp you left active.
In case this doesnāt ring a bell, lockout mode doubles as a momentary moon mode. That way, after locking it and tossing it in a bag, it can still be used to look around inside the bag without unlocking it.
There have been some complaints about the mid-ramp blink on the D4. I find it useful as a reference point, but some dislike it.
Should the FW3A have mid-ramp blinks?
Currently the default setup is:
- Smooth ramp floor: Lowest setting which lights up.
- Stepped ramp floor: About 10 lumens.
- Both ramp ceilings: Highest regulated mode, 8x7135 or about 3 Amps or ~1000 lumens. (full FET still accessible via turbo)
- Blink when passing 1x7135 boundary, ~150 lumens, or level 65/150.
- Blink when passing 8x7135 boundary, ~1000 lumens, or level 130/150.
- Blink when ramp hits ceiling.
- No blink at moon, because itās usually pretty obvious when it hits bottom.
A āblinkā means the light shuts off for 8ms. Each ramp step takes 16ms. So, itās off for half of that individual step, half of a 60fps āframeā, just long enough to see.
Soā¦ which of the following reference points should blink when the user hits or passes them?
- A. Floor
- B. ~150 lm, level 65/150
- C. ~1000 lm, level 130/150 (highest regulated level)
- D. Ceiling
Some prefer ānoneā, some might like āABCDā. I like āBCā. What sounds good to you?
When ramping down to the floor (or up to the ceiling) wonāt it simply stop? If so, I donāt think they need a blink.
I like the blink on my D4 so I wouldnāt mind B and C to give a point of reference as to the power Iām using.
That said, I wouldnāt care much if no blinks were the consensus.
Toykeeper is definitely the queen of flashlight drivers! That new UI is droolworthy!!!
Thanks, ToyKeeper, for such a great effort! The more I see this, the more āneedā the FW3A in my hands :smiling_imp:
I know we will all enter in the field of personnal preference while answering your question, and maybe it is ādangerousā to answer it here on this thread, risking to āderailā it to the FW and not the FW3A
At the same time, it is appropriate to inform the people interested on this light about the FirmWare it will probably use!
Here is a link for your other thread/post where other discussions may appear about this: E-switch UI Development / FSM - #234 by ToyKeeper
My personal answer/preference to: āWhat sounds good to you?ā
C and D !
Why C?
If we pass the C blink, we know the farthest regulated limit has been passed, so we may wanna go back a bit to enter the āregulated zoneā, helping to save some battery even with it producing near 1000 lumens.
Why D?
Sometimes I see myself pressing the Emisar D4 switch trying to realize when it reaches the highest limit, when ramping up. If there wasnāt any ātop blinkā we might get āstuckā pressing the switch, because we donāt know if the highest limit has been reached or not. So, the ātopā blink would be a nice indicator to let us move the finger away from the switch!
Why not A?
Obviously, as you said, the moonlight is easy to perceive when it is not getting lower!
Why not B?
If it will be regulated till the 1000 lumens, would it be necessary to have a previous blink to know the 1st regulated limit? Sure, it would help to save some more ājuiceā from the battery and produce less heat, but comparing to the D4 (as example), this one will have a wider regulated āspaceā so I donāt see a need for the B blink.
I donāt really mind the blinks as long as we donāt have ātoo muchā
2 would be great to mark some important points, but at least 1 (the C) may be important to have it!
My perspective, only!
Thanks for your work again
An esteemed and highly-sought-after title, to be sure.
