Would be nice to know if this is a flood-to-throw or not.
I would like a non-FtT with a lens
I just sanded a bit.
I got today my first prototype design boards from Schokis driver circuit with a 50W boost chip
I will test it next days, if the massive enhanced thermal connection added to the layout works well, then also some fine tuning the capacitors to get rid of switch on spikes and other stuff needed
I hope production can start end of february
Hi friends
A Korean branded 365nm LED available in KD.
Seoul Viosys UV 365nm Z5 Series CUN66A1B Ultraviolet UV Emitter
Triple 365nm LED with 20mm DTP Copper MCPCB (Parallel)
Enjoy
@BanL
I am searching for a 10mm XP MCPCB. The only one i can find on the net is the 10mm XP Sinkpad but it is only available at a few shops and only in the US.
So maybe you are interested in selling this size. Many of the small EDC light mods require this size. And i think many people from the EU would be happy to be able to order these MCPCB´s without paying 15$ for shipping from the US.
I thought most optics weren’t transparent to uv? Are the optics you are including with the triple uv led transparent to 365nm light?
Some optics are transparent down to 365nm. Not Carclo, but KD is using their own optic, I think I remember testing it for 365nm transparency and it was pretty good but not close to 100%.
Edit: just checked a KD triple optic again (it came with a triple Nichia 219B board) and the transparency for 365nm light (SST-10) is 50% the most when going through the <2mm top plate, so with the light travelling through the much thicker reflector part I expect considerably less than 50%.
Unless KD uses a different optic for this triple UV board…(my guess: =not likely)
Hi TheOnlyDocc, nice to see you around again, it has been a while. :+1:
I agree, a 10mm DTP 3535 board would be fantastic, I’m out of them for a while and although I’m a fan of VOB, shipping from his shop to Europe is pretty expensive.
Does this LED emit visible wastelight or only purple on the upper spectrum
I ordered one a few weeks ago, should arrive one of these days, then I can tell you. My prediction is that just like all 365nm leds it emits visible stray light, and probably more than the Nichia 365nm leds.
Hi friend
We just get a 12mm DTP 3535 board in stock. Are you interesting in that?
We can PM the details to you.
Thank you
Hi friends
Luminus SST-10 UV LED is available in KD
Thank you
Ban
May we know the bin kit order code? At least, give us an idea of the stocks you have.
I would be interested in the 12mm DTP copper mcpcbs for 3535 LEDs, especially if they come at an attractive price for 4, 8, or 12. (for now, I am assuming they won’t be cheaper than a quad 3535 MCPCB, which is one reason why I would want them)
http://kaidomain.com/p/S027435.DIY-LED-Flashlight-Host-130mm-x-47_5mm-Black
Note: quote was edited to separate image and product link for convenience.
I sort of second L4M4's interest on this host. Zoomie confirmation? Looks neat.
The pill looks like it does not have threads above the emitter deck, where the plastic retaining ring should go. This must be an optical illusion, doesn't it?
I believe amazing spill-free throwers can be made combining convex lenses with specially shaped reflectors tailored for the above lens.
“Fishing Flashlight Host”: is it waterproof?
Cheers :-D
Hey BanL can you get these 12mm boots in clear/white?
http://kaidomain.com/p/S025151.12mm-D-x-7_5mm-H-Glow-in-the-dark-Silicone-Tailcaps-Green-5pcs
They fit the BLF GT e-switch perfectly.
Hi BanL!
I am lookinng for boots too! But I was looking for 16mm boots suitable for Convoy S2+ in the purple color.
I see you sell purple boots but these are in a different size.
Here are the boot specifications from the Convoy Store.
Thanks!
Hey Kaidomain, can you supply transparent silicone caps for the BLF GT? I think they are 12 x 7.5 like these but in clear transparent silicone
Hi
We are searching for our warehouse to see we have this silicone caps or not.
Thank you
Ban
I am also interested. Is this host a zoom host or not?
