GoshDogIt posted about adding a length of bicycle inner tube over the battery tube. I mentioned maybe a neoprene sleeve would be a better cold barrier.
I found protective sleeves (for motorcycle forks) that fit perfectly in circumference, so I ordered two sets. The material is a little bit thinner than the OP/Tech hoods.
One fork tube coverwill do two battery tubes, so it needs to be cut in half.
Before cutting, the stitching needs to have a "stay stitch" sewn in on each side of the cut where you plan to cut it. To secure the stitching so it doesn't unravel. Here are the neoprene covers for anyone interested.
I don’t understand, I never got an email… I was in the group buy like 2 months ago… my name was posted…. please tell me I didn’t lose out due to them missing my name… forgetting to email or pm?
The next group (3rd batch) to purchase lights (#1050 and up on the list or who signed up after 10/23/17) will get their emails late January to early Feb in order to let Neal get caught up with current orders. Since Chinese New Year is quickly approaching, Texas_Ace may wait unto late February. No final decision has been made yet.
Thank you all for your kind suggestions. I appreciate the information. I will continue to wait patiently and check back later this month and throughout February.
When I receive the email / pm, how long do I have to take advantage of the price? Do I have to buy within a very short time limit of my receiving the email? (Basically, if I don’t see the email until 2 weeks late because I forgot about it, will I miss out, or is the coupon good for a month or longer?)
gregor, I understand your frustration about this. Obviously refund is not what you want. You just want confirmation from Neal.
I think Neal should respond to you if he can. You should try PM him again, of course i am not suggesting to spam him everyday.
I like it srwaite! I thought it’d work perfectly and it looks like it does… I would’ve been all over it but the funds department cancelled my little party…
Does it “handle” as well as it looks like it should?
In your first photo, are there 3 or 4 beams being thrown; It looks as if there are 2-3 beams on your side of the lake? Maybe just a glare but from the right side of the photo it looks as if 1 beam is crossing over yours and possibly another is shining down yonder…
The bottom photo…WOW! From that distance it’s amazing how bright that looks!
I like it. It feels great in the hand and the balance is perfect. The only real problem is that with only 1 screw to hold it in position, a rapid twist of the hand will cause it to rotate. I can’t get enough tension on the tripod screw to prevent it, although you really have to twist it pretty hard to make it move. I’m considering machining 1/4” off the front of the handle base so it can butt flat up against the fins of the GT and maybe prevent that. I’m not sure if its necessary yet.
