So this will have lightning and candle blinkies? Is party strobe the one that makes movements look slow motion, and will this have that too?
Hi,
can you put me on the list for 2 pcs?
I asked some 20 days ago but still can’t find myself on the list.
Thanks
When will the list be updated?
I signed up a few months ago.
The list hasn’t been updated ever since.
I can’t find myself on the list.
For me option B and C please.
Thanks
Ps: i allready love the ui
I like moon and max. Like my photon freedom. :slight_smile:
I like the blink at moon because the Crescendo UI ramps down and up without stopping. and I like to know when I reach the bottom of the same reasons people like to know when the top is reached. Don’t like to press again to make sure.
The B/C option sounds reasonable, Thats just my preference; to many blinks would be annoying.
ABCD blinks.
One thing I don’t like about ramping firmware is not knowing where I am, how much power is being used.
Blinks at these stages help greatly.
Personally I like the blinks at A and D. C would be helpful to know when you are leaving/entering full regulation. I don’t think b is really needed as you can just have it where you need/want it
If you are ramping up and hit the C point are people actually quick enough to stop it before it ramps over? I have a habit of redoing contact with the tail on the D4 to make sure it’s at a regulated level.
My preference is no blinks. Maybe a blink at D but definitely no mid-ramp blinks. Ramping UIs are much cooler when you can smoothly go from moonlight to max.
I think if there was a ‘shortcut’ to a known regulated level, ie 150lm, does that negate the need for blinks for some users?
Just my 2c though, naturally you should do whatever gets most votes.
Put me in for one please. Thanks
Will be good if it possible UI can be switched to very simple mode so old and other people can use it.
For ex. On-Ramp-Off, On-On-Turbo-Off.
Enough…
And even with incorrect clicks, the mode can not be changed. Mandatory without memory, so always can starts from known/familiar position.
Maybe something like 16 clicks for total mode changing…
Some older people I know lost themselves in Q8 because of their short memory and the many features/modes of the device.
You know that when we buy for our parents, the price is not as important as the exact satisfaction of their needs.
Please add me to the list for one. Thanks.
For me B/C too.
The list on the Original Post is not updated as The Miller has been away for some time!
Member pepinfaxera is updating the list on this post:
Your name is already there, #782 :wink:
FWIW, here’s the running vote tally…
As a reminder, the options are: (where in the ramp to blink)
  • A. Floor
  • B. ~150 lm, level 65/150
  • C. ~1000 lm, level 130/150 (highest regulated level)
  • D. Ceiling
Totals:
  • A: –4
  • B: 4
  • C: 9
  • D: 2
14 votes:
Yes.
I’ve been meaning to change that, actually… do you think Crescendo should stop at the ends of the ramp? After spending more time on other ramping UIs, I’ve found it’s nice having it stop on its own.
On the FW3A, at least, the plan is for the ramp to stop at both ends. To turn around, release the button and hold it again.
No, it’s a single frame at 62fps, too quick for a human to respond. People aren’t expected to be able to do frame-perfect inputs.
The D4 thing (loosen tailcap, press button, tighten tailcap, to reset to 150 lm) doesn’t work well on the FW3A. It can be done, but it’s a bit more tricky because loosening the tailcap also disconnects the button. To make it work, you either need to wait a while or loosen it while the light is actually on. And then on reconnect, at least on my prototype, sometimes the contact ring gets a bit wonky so I have to loosen/tighten again to re-seat it. I think that’ll be fixed, and it should only affect the first prototype, but I’m not 100% sure yet.
However, for anyone who wants to hit precise levels every time, it also has a stepped ramp which can be configured to your specifications. It can have anywhere from 2 to 150 evenly-spaced steps, starting and ending at any of the 150 levels. The default right now is 7 steps from ~10 lm to ~1000 lm.
See above. :slight_smile:
It has a mode specifically for this purpose. It’s called muggle mode.
The details are still up for debate, but so far this mode is about as simple as it can get. Only one level (150 lm), and the button merely turns it on and off. Once in muggle mode, it stays that way until the battery is removed.
To enter muggle mode, click 6 times from off.
There are basically three simplified UIs:
  • Lockout (4 clicks from off): Acts as a momentary moon mode, using the floor of the current ramp. Click 4 times to exit.
  • Momentary (5 clicks from off): Main emitter is on while button is pressed, or off otherwise. Uses the last-ramped brightness level. Good for Morse code and such. Physically disconnect power to exit.
  • Muggle (6 clicks from off): Extra-simple UI. Useful when non-enthusiasts borrow the light. Physically disconnect power to exit.
Hopefully that covers most needs.
If you aren’t expected to be able to hit the mark then the blink seems a lot less useful to me? It seems like if regulation is very important to someone they could set a ramp ceiling at 130/150 and allow dbl click to 150/150 and ramp down from there for 131-150 or would it not allow that and go from 150 to 130 when you ramp down from turbo?
Your name is already there N° _ 897 and 898
. FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #2127 by pepinfaxera
Tried 6 times from off. Just played with my Q8 and I had to remove the batteries again…
An elderly man can not remember how many times 4-5-6 he has to click on a flashlight mode.
Yes, stopping would be good in my opinion.
