Some time ago I decided I needed some serious 18650 batteries . Looking on Feebay I came across the SONY VTC4 rated to 30A continuous discharge . Hmmmm , I called BS on this claim but purchased a pair in anyway as I like to test stuff before speaking out of turn .
I have no way of testing 30A discharge …
But what I thought might be interesting was seeing if these batteries could power a RC buggy ( WL toys 12428 4WD ) …
To that end I built a battery carrier with some spring bye passes ( dont put in spring bye passes ? and the springs will glow like toaster elements ) …
Those first 2 batteries were awesome …
This is a test with a 2nd set of VTC4 from another Feebay source … And color me impressed .
Now I have 4 x VTC4 for flashlight testing .
Ambient temp during the test ( drive ) was 31 deg Celsius in the shade … ( Yes the batteries got warm - toaster oven warm )
And when I noticed how warm the batteries were I ended the test . ( batteries can move in the cradle and break contact ) = It is a 4WD buggy after all …
All previous testing was done in cooler conditions and with the Tx set to 50 to 60% Throttle …
This test was with the Tx set to 100% and it was much warmer …
So the discharge current would have been very high .
An 18650 can get hot enough to further shrink the heat wrap to the point it cracks and splits.
My experience is that by then there is perminate damage to the cell.
I have had a 18650 cooking hot ( after a short ) , and that battery was ok for over half a decade …
These Sony were hot , but not hot enough to be damaged … ( Well I hope not )
But when the 18650 lost contact in the carrier , I figured the batteries had proven themselves .
But certainly a brutal test for a 18650 …
But these Sony rock hard … And should prove to be awesome in a flashlight .
At least I will know that these batteries wont be holding back performance .
Also they are really well matched for capacity and discharge .
I don’t know if you can buy a better 18650 for the money ?
Mooch rates it at 25A. He says At 30A continuous the temperature rose to 92°C. This is way above the average temperature of a cell running at its CDR and is an indication that we’re above the cell’s true rating
