The c8 is the obvious choice for a $20 thrower, but if you don’t like the shape and size, maybe try a BLF x5. You can’t really tell by the pictures, but this is a much smaller light. I don’t have one but it seems to kick a lot of but for it’s size.
Gonna mod it? As-is, the Ultrafire F13 is nice and throwy, I like the design and feel, but the come-with UI just pisses me off. I swapped in 1-mode 22mm drivers for nice dedicated throwers.
The Sofirn lights are really well made (I was surprised at how good it was), and has a slim profile, dual buttons and is very bright for it’s size. The clip is nice and sturdy, with little flex. The knurling and anodized finish are satisfying. Definitively a very, very good deal, as long as you don’t mind waiting. You’ll want to get a High drain cell, and it can be flat-top because of the dual springs.
Now, you want throw. This thing will throw 300+ feet (100M). The beam widens, and isn’t as narrow as a C8, etc, but still travels far.
Eagle eye x6 you’ll love it. It became my edc I use for work daily. 3.5 am turbo for 3 mins. For a decent 20 buck light doesn’t get much better then that. I have like 5 x6 and 5 c8 or something now. I make brothers of each kind. Fet driven xplhi v3 well have to build x6 the same way. Need a couple more host. Time to make a couple with the new sst40 led
Edit for around 20 you can put your own light together. You’ll feel great the first one you do. Convoy host $10, led 3 to 6, driver 4 to 10 dollars.
The new s2 has a smooth reflector but a tube light only throws so much. The convoy m1 is the best all around light I’ve found. Mine has xpl2 w2 2b emitter making 1800 lumens. And it throws plenty and lights up the area. My second pick would be the eagle eye x6 with the same emitter Fet driven. Amazing light output. And with a little mass takes awhile to really heat up.
Richard at MTn has some lights ready to go.
If you buy the parts and pay shipping I’ll put a light together for you.
Since the Eagle Eye X6 was mentioned, would the Astrolux S2 (aka BLF X6v2) be considered a better version of the Eagle Eye X6 or is there still some pros of the EE X6 over the Astrolux S2 (BLF X6v2)? The Astrolux S2 is around $23.95 during “promo” sale periods (which seems to happen relatively frequently).
I like my Astrolux S2 when I need more throwy situations while being a relatively compact portable light — being FET-driven (Bistro firmware), it seems to be at least as throwy as the Convoy C8 XP-L Hi (which I also got) and they have also nearly the same weight (the Astrolux S2’s head is quite heavy), but Astrolux S2 is slightly smaller.
I know you said you didn’t like the look of the C8, but it really is the best budget choice. The silver Convoy C8 is a good choice (don’t get the other colors of Convoys, because their UI isn’t very good). For a few dollars more, there’s the Astrolux C8 which has higher output and throw. I reviewed it and compared it with the Convoy here:
Id say that, and theres good deals going down on them here on the forum
$28.99. I would go with the 5000k tint. Its probably my favorite tint I have right now in all of my flashlights
The UI is good on it, but I would love to have the same UI as the GT on this light
Everything’s a variation of a theme, nothing terribly different if swapping for a 3D, 5A, etc.
Only the driver was a little tricky, that the wires had to be “unlooped” to not bang on the shelf above it. Plus, I used one of those PET insulating discs to further insulate it from the shelf, just in case.
Other than that, it’s a straightforward mod, nice’n’easy.
The 3D is (to me) a bit on the cool side, rally should’ve tried the 5A/5D first. Well, that’ll learn me…
Well at least the H2-C has hidden strobes, so basically a 4-mode ML-L-M-H, but I could do without the ML (0.01%)
Too bad no one makes one of these with firmware like the Dr. Jones Guppydrv, I have a few 17mm FET drivers with Rev1, they can be set to various groups, including single mode 100%, for an emergency light.
The thing is I can’t seem to find any other “off the shelf” single cell 12v boost drivers for XHP35, this is the only one I know of, do you know of any?
