I have a D01 with copper pill, that is one massive chunk of copper. Not a bad buy at all!
any more ?
thanks
Sorry?
Funny, but I have reversed almost all my thoughs about Q8 modding.
Actual situation:
1.5mm brass tail boards - got to much pressure from tailstock when machining. They are too ugly to sell them as is, same way Im to busy to sand them for better look.
Hex wrenches - in stock
SS tail screws - in stock
Springs - in stock (Im going to make positioning tool and solder springs to the brass boards)
Brass buttons for positive cell side - in stock
Board sets for 2S2P/4S mod - in stock - have wrong OD caused by manufacture error
I still dont know how to “set” this parts together, open for your suggests.
My ideas about 2S2P/4S mod were too complicated, I dont see this way reasonable. Anyway, Im still thinking that mine idea with “medium board” (extra pcb between driver and cells) is ways more safety than regular decision (with separate contacts pads on driver) and Im asking driver developers to think in this direction.
Same time, Im back to the idea of 12 leds in Q8. I went wrong way previous year, but because of abilities of one blf member, project seems to be alive.
Received my 2nd order today, thanks kiriba-ru! Everything was nicely packaged and arrived in good condition. Can’t wait to put the x7 triple together : ), just waiting for some other parts from elsewhere. Also looking forward to seeing how your q8 12 led mod develops!
Tail+medium boards for 2S2P or 4S mod (both are oversized (47mm) so you need dremel to sand them down)
4 x brass buttons
4 x springs
8 x M2.5x6 hex screws
$1 set without wrench
$2 set with usa-made 1.5mm hex L-wrench
One respectable seller forget to ship out some parts for this project, so it is delayed :weary:
Can I order it?
Sure.
If you know what to do with them.
I will have some more suitable rings (existing positive q8 rings a too thick to use a pair of them in such config) soon, if you need them you can wait about a week.
BTW, if Im not mistaken I have contacted you with PM about solid brass tail boards. Still would like to know your opinion.
I can not express my correct meaning in English.
I’m sorry if I missed this in a prior post but, P60 solid Cu 18350 neck+S2+ Cu pill inside $25 155 g…what is this?
This is drop-in substitute. You can build full head and change them “on the way”.
Upd.
This set was made for quad build. But if you have shorter pill you can use single led with some optics or reflector.
Hi,
one of one Jaxman Mini C8 Quad. 4x Nichia D280, FET Driver and some GITD. Nice work!
Regards
Kenjii
Damn i’ve missed all the good quad spacer runs
I want an M8 quad!
Kenjii got full height pill for M8, not simple spacer.
Sure that works too. Take my money
I wouldnt make more of such pills. I can think about spacers, but not sure that M8 (with brass pill) is suitable host for this.
Is the full pill too difficult to make or too expensive to sell? I know the M1 had the expensive optics and machining but people seem to like the quad kits dont they?
