I’ve got a similar model with a sheepsfoot blade. Don’t know if the steel is real, but it’s a handy little knife that rides unnoticed in my coin/zippo/pocket watch pocket. Too bad it’s a blatant knockoff with the SP logo though.
Mine arrived hair shaving sharp.The best pizza slicing knife I’ve used,the cleaver,I suppose.It was checked,and passed by superviser,in security check in Nice airport as hand luggage,London also.UK legal.
It’s a wonderful knife that you’ll never have to baby. I’ve used my Moras for kitchen tasks, camping, bushcraft, fire-making, yard work, whittling…it just works well. It’s also surprisingly light for a full-sized fixed blade.
If you mean my copper colored Fura kwaiken (at the bottom) that`s an excellent flipper with a nice fit & finish, it also feels comfortable in my hand. The blade is quite thick (4 mm) considering its width so it`s not my best slicer but I can live with that. I also like the green version.
I got such a green Fura for my job student. It feels great in the hand, the surface is smooth (bead blasted?) and the green anodization is very even and same on both slabs.
The blade is way too thick though, I’m thinking about asking a knifemaking friend to put a hollow grind on it, even though that would have been easier with the tanto version (hollow straight edge, flat tip).
The new owner likes it but for me the flipping action feels rather portly than solid, the blade is just a bit too heavy for its length.
Some folks may like that though and for less than $30 it’s worth to try.
I would however strongly suggest to right away disassemble the knife to remove titanlium splinters and other dirt.
Especially the grease must go as it just slows down the action.
I’ve added a drop of mineral oil but I assume it runs same well when dry just like my SRM Land 910+.
I can only say they do a damn fine job with bead blasting and anodizing on these FURAs.
And I’ve played with that stuff a bit, sometimes it’s not easy to get the same color on both of the slabs.
The blade is thick and heavy but the surface treatment is top notch!
The kwaiken böker is beautiful, even the color.
By the way, the kwaiken green fura is with tanto tip too but with other colors. It is an interesting knife for its simplicity in design.
I have the opposite problem.
Since I’ve thinned out the blades of my Vespa Neon and the Malyshev Gnome I feel these 2 are all the knives I need, either on job or at home.
How can I tell myself that it’s ok to buy a Hungarian traditional knife for ~$70 and maybe a Zieba Ti clone when I still have a Y-Start Damascus knife and a Sanrenmu dragon scaled one in the this time super slow Gearbest transport?
