WOW indeed, power but also dirty amounts of runtime for example as a nightlight :+1:
1 for me, thanks.
This little light should be really handy for general EDC use, but with the benefit of some power up top when needed. Of course, it won’t run long at Turbo levels in a light this small as heat will become a paramount issue, but it’s really nice to have it there when you need it and TK gives us the ability to set a ramp ceiling at a nice usable level with a quick double click going to Turbo for that on-occasion need of a blast of light. That really makes it a great application in my opinion, I use the ramp ceiling at around 60-75% such that a double click really steps it up, this lets me easily control power drain for the best EDC capability to date.
Sign me up for one please!
Count me in for one please!
I didn’t have the graph earlier, but here’s how the latest thermal test looked.
This started adjusting from the highest current-regulated level, which measured about 1100 lumens or close to 3 Amps. Output stabilized at about 7 minutes. I haven’t tested it on full FET yet, but I suspect it will probably need some changes in the response curves to make it react faster.
Wow TK,the UI looks amazing. Thanks for the table and graph. Great work. Looking forward to playing with the light and using it as my EDC.
Pepinfaxera, can you put me down for a second light please.
Thank you
Do you know at what temp about it stabilized at?
For testing purposes, I set the limit intentionally pretty low. I was aiming for a stable level of about 200-400 lumens, and … that’s what I got. I think I told it that the ambient temperature was 20 C, and set the limit to 43 C, but I don’t remember exactly.
I wanted it to exceed the limit pretty easily and then step down somewhere slightly above the 1x7135 level. I could have set the limit much higher, but that makes the regulation problem easier to solve… and I wanted to see how it behaved on a harder setting.
Next I need to do full FET testing, since it’s the next step up in difficulty.
Looks like it worked as intended. Be interesting to see what it would do around 55c limit. What can the components tolerate? Typically up around 100c right?
I expect that turbo will overshoot the temperature limit before the light can settle to a stable level, so I wouldn’t put the limit too close to the hardware’s maximum tolerance.
The thermal sensor is inside the tiny85, which doesn’t have a great thermal path to the emitters. The measurements lag behind by quite a bit, so the response is lagged too. It tries to compensate for this by guessing where the temperature will be in the future, but that doesn’t entirely eliminate the problem. So the actual temperature goes higher than the limit at first, if the power is turned up high enough.
The firmware won’t allow a limit higher than 70 C… but it lets the user calibrate the sensor, so it’s not very hard to bypass that limit.
On a related note, that could potentially save a bunch of button presses while configuring things. If you tell it room temperature is 1 click (1 C), and then set the limit to only 1 click (30 C + 1), it’ll effectively have the same results as if you set room temperature to 20 C and the limit to 50 C. But the tempcheck mode will display numbers about 20 C too low.
I do not see him registered
In for one
Your name is already there nº 332 from The Miller list
A second unit?
Your name is already there nº 332 and 999
Updated list : … Post moved to Page 130 , FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #3870 by pepinfaxera
Short list, Last requests .
Add me to the list please
- A. Floor
- B. ~150 lm, level 65/150
- C. ~1000 lm, level 130/150 (highest regulated level)
- D. Ceiling
I’d like it to blink on C
So… which of the following reference points should blink when the user hits or passes them?
- A. Floor
- D. Ceiling
I vote for all A, B, C, and D.
I find the blinks very useful and not obtrusive at all.
There seems to be a lot of differing opinions about the blinks. Would it be feasible to have toggles for the various blinks in settings?
Thanks for all your attention to detail. This UI is looking amazing.
