If you mean my copper colored Fura kwaiken (at the bottom) that`s an excellent flipper with a nice fit & finish, it also feels comfortable in my hand. The blade is quite thick (4 mm) considering its width so it`s not my best slicer but I can live with that. I also like the green version.
I got such a green Fura for my job student. It feels great in the hand, the surface is smooth (bead blasted?) and the green anodization is very even and same on both slabs.
The blade is way too thick though, I’m thinking about asking a knifemaking friend to put a hollow grind on it, even though that would have been easier with the tanto version (hollow straight edge, flat tip).
The new owner likes it but for me the flipping action feels rather portly than solid, the blade is just a bit too heavy for its length.
Some folks may like that though and for less than $30 it’s worth to try.
I would however strongly suggest to right away disassemble the knife to remove titanlium splinters and other dirt.
Especially the grease must go as it just slows down the action.
I’ve added a drop of mineral oil but I assume it runs same well when dry just like my SRM Land 910+.
I can only say they do a damn fine job with bead blasting and anodizing on these FURAs.
And I’ve played with that stuff a bit, sometimes it’s not easy to get the same color on both of the slabs.
The blade is thick and heavy but the surface treatment is top notch!
The kwaiken böker is beautiful, even the color.
By the way, the kwaiken green fura is with tanto tip too but with other colors. It is an interesting knife for its simplicity in design.
I have the opposite problem.
Since I’ve thinned out the blades of my Vespa Neon and the Malyshev Gnome I feel these 2 are all the knives I need, either on job or at home.
How can I tell myself that it’s ok to buy a Hungarian traditional knife for ~$70 and maybe a Zieba Ti clone when I still have a Y-Start Damascus knife and a Sanrenmu dragon scaled one in the this time super slow Gearbest transport?
Thanks I’ve been looking at allvin store for a while, been considering the Makora II OTF.
Just followed your link and noticed these Ganzo G719 clones with carbon fiber and/or damascus. Very interesting, I have a G719 black G10 and it’s basically a precision work of art.
The Ganzo only have the G10 scale on one side (Button side only) But these have the scales on both sides! So i’m excited a bit about these! Although I wonder if the damascus version is real damascus.
The “real” G719” seems to be discontinued, I’m wondering why they didnt’ just put the Ganzo logo onto this one as well.
How much is the non-damascus version btw, $50 for that one sounds a bit expensive.
And it is real damascus, that stuff is not that expensive. To get such a pattern it would be more difficult to laser or mask+etch it and the pattern would be the same on every piece.
You can still get the real G719, I’ve seen it at a few sites, here’s one:
The non Damascus CF clone is $24, you can just click on the photos I posted for the links.
Maybe it’s real Damascus on those but no offense fake Damascus pattern etch is not more difficult or expensive, and definitly not the same on every piece. It can be found on tons of cheap knives everywhere, many sub $10 knives such asTac-force etc.
Of course when you knife what you’re looking for you’ll see the difference esp. where the main grind begins at the ricasso or at the blade spine.
$24 sounds ok but when I see the prices of today’s China made knives it’s still a bit expensive, I think I paid $16 for my G719 (and had the intention to turn it into a manual button lock folder but bought a RealSteel Griffin instead). I also strongly believe this is a Ganzo made knife, too, it would be silly to copy the knife when you can just ask th original manufacturer to make another batch with the set machinery (same for the CRKT Swindle copy that appeared and imo must be nightshift production).
The best thing about that CF G719 must be the weight reduction due to the ligher clip side, the original G719 is rather heavy and I always wished they’d have used 2 G10 or CF scales.
