Complete list of Texas_Ace LED tests with user adjustable comparison chart
30 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 22 hours ago
Gchart on here was nice enough to find a site that allows for different charts to be easily compared by the user. Thanks a lot for this, this should help a lot of people, including myself.
He then was able to input most of the LED tests I have done so that you can easily compare them.
Very cool and a great tool for those wanting to compare LED's.
https://public.tableau.com/views/LEDTestingChart/LEDTestComparisons
It doesn't include all the advanced info from my charts, so here is a link to all the charts I have so far as well.
Complete collection of all my raw LED test Charts
Here is my master list of LED tests, it has all the raw data, some of it will not make sense to anyone but me but it is all there.
Raw data for all Texas_Ace LED Tests
And here is a list of all the LED test threads I have on BLF for easy searching as well
My LED Test series - XP-L2 V5  - Nichia 219C 90+ CRILatticebright "XM-L"XHP35 & PWM efficiency - XHP50 - XP-L V5 - XM-L2 U2 - XP-G3 S5  - XP-L HI V2 - Oslon Square & direct comparison to Djozz tests - Nichia 319A - Nichia 219B 9080 CRI - Nichia 219C D320 - Nichia 229AT - XHP70.2 P2 - XHP50.2 J4 - Samsung LH351D
Edited by: Texas_Ace on 02/19/2018 - 08:33
pommie
Last seen: 19 min ago
Bookmarked, thank you very very much TA and Gchart Beer
Cheers David
Nothing to see here folks, move along...
RotorHead64
RotorHead64's picture
Last seen: 9 months 3 weeks ago
Subscribed. Thanks
gchart
gchart's picture
Last seen: 28 min 18 sec ago
You’re welcome, all. I hope it helps; I know I’m finding it useful. And thanks again TA for running all of these test.
WalkIntoTheLight
Last seen: 4 months 4 days ago
Very interesting. It’s easy to see why FET-driven lights using quad Nichia 291C emitters get so hot! I’m surprised they don’t fry the LEDs with such a low forward voltage.
fishymamba
Last seen: 2 years 1 month ago
Thanks for all your emitter tests! Have really come in handy while building my first few flashlights!
S8 Triple - 219c, MTN-17DDm
M1 - XP-L 7a, 105c
C8 - XP-L HI, A17DD-L
CRX
CRX's picture
Last seen: 2 hours 43 min ago
Great! Thanks guys Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
MRsDNF
MRsDNF's picture
Last seen: 1 hour 34 min ago
Nice work guys. Very handy data and even easier to compare now. Beer
gchart
gchart's picture
The chart has been updated with recent results from TA’s test of a Cree XHP70.2 M4 4000K 80 CRI. Check it out here
Mike C
Mike C's picture
Last seen: 4 weeks 1 hour ago
Cool chart! Thanks.
Agro
Agro's picture
Last seen: 1 hour 9 min ago
TA, it would be useful to see a power / output chart as well. Right now it’s practically impossible to compare XHP with 3V LEDs..
Would adding that be possible?
gchart
gchart's picture
Shouldn’t be an issue, I’ll take a crack at it
Texas_Ace
Texas_Ace's picture
Agro wrote:
TA, it would be useful to see a power / output chart as well. Right now it’s practically impossible to compare XHP with 3V LEDs.. Would adding that be possible?
If you click the direct links to my tests in my Sig it lists the power and outputs for all the LED’s.
Got to compare it the old fashioned way but it works. If Gcart can make up a graph for comparing by wattage and/or efficiency that would be really cool as well.
moderator007
moderator007's picture
Last seen: 36 min 14 sec ago
Thanks to you both, nice to have graphs to be able to predict vf and lumen’s before you even build a light.
I have used the data a lot, very helpful. The comparable graphs make it even better. Wink
Mike C
Mike C's picture
My favorite isn’t in the list. You never tested a MT-G2?
Texas_Ace
Texas_Ace's picture
Nope, never even seen an MT-G2 myself.
EasyB
Last seen: 17 min 3 sec ago
Thanks. Having all your LED tests in one spot is very helpful.
contactcr
Last seen: 36 min 23 sec ago
Would be cool to add some tests from other users (assuming they have similar setups and agree to it)
Especially would like to see SST-40 and Luxeon V.
Texas_Ace
Texas_Ace's picture
The results from different users are not directly comparable in most cases.
None of us have professional spheres but standard calibrated spheres. Since all of our standards are different our readings also vary some.
That said for the most part we are reasonably close all things considered as long as you don’t overlay the graphs.
Plus even small things like the reflow of the LED can have large effects on the results when pushing things to the limit.
Doing separate charts for other testers would be cool but overlaying them could lead to more confusion and issues then it helps when they vary by 10-20% in some cases on paper but in the real world are the same LED.
contactcr
I agree the specifics of testing are important but honestly I bet you could take one of your Nichia and Cree tests (219 & XPG3 or something) and the same LEDs from djozz and come up with a Texas to Amsterdam factor.
Texas_Ace
Texas_Ace's picture
Yeah, me and Djozz have talked about this in the past. The problem is that the difference in our results varies LED to LED making it hard to give a good number across tests.
Some of this is the variation in binning from Cree, they have a 14% tolerance for each bin, and some are from minor variances in our own tests, like reflow, temps ect and the rest is the setup.
Agro
Agro's picture
May we get the raw data behind the charts?
Texas_Ace
Texas_Ace's picture
If you got to the individual threads for the tests you can see the raw data. This comparison is simply to compare different LED’s.
Agro
Agro's picture
Yeah, but writing it down from the pictures is quite a laborious task… I’m sure you have the data available in editable form or else the charts in this thread wouldn’t exist.
I tried downloading the chart data from tableau, but got some weird format that requires proprietary Windows/Mac software to read. My machines run FreeBSD or Linux. Tableau has a web editor, but before I started it I saw a remark “You will need Tableau Desktop eventually”, so I gave up.
I would really appreciate help here…
Texas_Ace
Texas_Ace's picture
That is part of why I have not released the data file, it is excel 2013 based and all the charts seem to make it unstable. Excel crashes on me regularly when I have that file open.
I will look into converting it to another format and releasing it though.
Agro
Agro's picture
I would be happy with any format. Excel 2013 is as fine as anything. I can do the conversion for you and for others.
Texas_Ace
Texas_Ace's picture
OK, I ran a repair on the excel file and it seems to be working better now. I uploaded it in the OP.
Agro
Agro's picture
Thanks!
vulpes
vulpes's picture
Last seen: 3 days 43 min ago
Thank you for sharing this!
prototype3a
Last seen: 1 week 4 days ago
Could you make a graph page comparing lumens to watts and then maybe add the Vf range next to each particular LED?
