I am already impressed by my āoldā OnePlus3 screen and camera (ability to take bright photos even in low light situations)ā¦yours should be more improved. I am planning of upgrading mine too.
Gearbest had a flash sale of that variant for I think $435 something if I recall correctly.
Iām starting to look for a replacement for my Nexus 5X. This 5T looks interesting, but unfortunately it says itās not compatible with the Verizon network. Iāll have to keep looking.
Oh, I suggest you should try using its Dash charger technology instead of the usual slow or 1A charger. Itās NOT only for convenience. Hereās why?
Itās like this: In OnePlusā website about this technology, there is some kind of circuitry in its original charging cable that though the charging is fast, the battery does not heat up because that special circuitry routes the heat back to the power supply adaptor, INSTEAD of the battery. Have you noticed the phone barely gets warm when its original charger set is used?
I bought several micro-usb-to-usb-C adaptors connectors just in case the original usb-C cable malfunctions. I tried it once (used my iPhoneās USB adaptor with a good micro-USB cable and put in the usb-C adaptor) and the phoneās back portion heat up a lot more with the slow or low charging rate!
At the upper-left portion of the phone, the is a led that glows purple when Dash charging (original adaptor/red cable should be used) and yellow if some other charger is used at a slower, ānormalā rate.
And itās been a well-known fact that heat is one of the major factors that brings lilo to its earlier demise.
I have charged my 5T with the Dash charger and it does charge fast, but Iām not so concerned about speed. Iām more concerned about convenience. Iāve done some google researching, and the general consensus is itās ok to use a no-oem high-quality charger like an Anker. Also, I have portable chargers from Xiaomi and Anker I want to be able to use in case of a power outage. All I care about is that these aftermarket chargers wonāt damage my new phone. From what Iāve read they wonāt.
