To my surprise I got the light finished before fetching my son from school. Did it a bit selfish though: did not make pictures of the build apart from the result. These are the steps I took though:
*removed the switchboard from the host and fully test-wired (with test-XM-L2) the 17mm NarsilM driver that I got from Lexel (his service is a real help for the BLF community, thanks!) It worked fine, including the switch-led functions.
*removed all internal parts and blowtorched the three body parts (not the bezel because is not used. The tail got a bit too light-brown so I stopped earlier with the tube, and still earlier with the head.
*attached the Convoy SS bezel and sanded the bezel flat with the disc sander, took a while because I need to replace the sanding paper disc. Bevelled the edge
*sawed of the ears of the tail part and sanded the tail flat. Bevelled the edge
*replaced the green leds of the switch-board with orange ones, and replaced the two 33 KOhm resistors on the switch-board with 3.3 kOhm ones, so that the orange leds are at least as bright as the green leds were.
*the Lexel 17mm NarsilM driver has 7135 chips on the battery side so the driver retaining ring hardly screws in. So I bevelled the inside of that brass ring quite a bit, but also filed the corners off the 7135 chips.
*Soldered a connecting wire for the swich leds to the switch board (the host comes without one)
*reflowed three Nichia 219C SM4070e R9050 leds ( :heart_eyes: ) on that great DTP copper triple board that this host comes with.
*opened up the center pieces a bit with a hand-countersink device (they were blocking a bit too much light to the side)
*attached long (~7cm) ledwires to the board.
*assembled the head tight, with generous Arctic Silver 5 under the ledboard.
*soldered the five wires sticking out of the head to the correct pads on the driver, the led+ wire directly through the center hole of the driver to the top of the driver spring.
*pushed the bundle of wires into the hole, pushed the driver in position and closed the retaining ring.
Done! And everything went well without too much troubleshooting needed.
A few performance results on a 30Q battery:
*11A with battery full, the long ledwires limit the current quite a bit.
*2080 lumen at start, 2040 at 30 seconds. Just 2% drop, this light is steady alright!! Efficiency at max is about 50 lm/W, which is not great.
*perfect tint and colour rendering, great beam: beautiful hotspot, tintshift as little as you would ever wish
*UI= :heart_eyes: , as expected from NarsilM, with lighted switch when off.
Pics:
^ white balance was on auto, above picture shows the beam quite well, but not the tint.
Conclusion for this Sofirn C8F host: you get an immense good host for almost no money, well done Sofirn+BLFdevelopers! It is a bit more challenging building this up than a simple C8 or a S2+, but there’s at least no stupid design flaws that needs building around. The amount of aluminium in the right places, the thick and flat shelf and the copper DTP board make for great heat spreading, I still need to check but in my build a stepdown may not be needed before 10 minutes.
Edit, costs (not too bad this time )
Host $13.21
SS bezel $4.50
Driver $14.50
Nichia leds $14
Switch leds/resistors $0.70
Total $46.91
Nice build djozz, like it a lot. Cool customization on the bezel, tail and bake.
also liking the XP-L HI throw g_damian.
Got a few C8F hosts to play with. Just haven’t touched them since modding the first C8F I got as complete light.
Thanks for posting your info and specs guys.
I’m just getting back into modding and upgraded a Thorfire TG06S with a FET, XPL2 (4000K) and Efest 14500 (2017 ver).
Not sure how many amps its pulling but based on battery sag and XPL2 Vf, it’s hopefully somewhere around 6-7 amps for 1700 lumens!
Pretty bright for a keychain flashlight and blows my old Astrolux A01 out of the water.
I highly recommend the TG06S as a 14500 modding host/EDC. They can be had for around $13.
The XPL2 die is exactly the same size as the XPG2 it replaced so no need to mess with the reflector either.
Thermal management is OK, but it didn’t heat up as fast as I was expecting. I think the aluminum pill/shelf is a bit thin.
I have upgraded a cheap silver S2+ from GB which had the V21A xpl hi and 3/5 mode convoy 105 driver.
Replaced it with an XPL2 HD 5000K and a BLF A6 driver to make a small pocket rocket, it gives a lot of light, did not measure current draw, but i am not happy with the tint, it’s ugly as hell!
Hot spot is OK but it has an ugly yellow corona which is very annoying to me.
3.45 x 3.45 mm for both right? Unless I screwed something up (which is common).
The factory centering ring fit just right for the xpl2 so I’m happy
My builds rarely go together as smoothly as this one did.
You are talking about the package size, 3.45 x 3.45mm is the standard “XP” package size.
The die is the yellow part of the LED that actually lights up. The die of the XP-L2 is just about twice as large as the die of the XP-G2 (depending on which version of the XP-G2 you mean, Cree modified it a few times). This means that in the same flashlight the hotspot will be twice as large when you replace an XP-G2 with a XP-L2.
This is also shown be the higher maximum drive current in the datasheet.
That’s funny, I also thought the overall size of the XP-L2 same as XP-G2. Bringing this kind small detail is so educative. Footprint is the correct word, not die. So now I can say that XML has same footprint has XML2 but different die. Thanks for the reading!
In Cree parlance, the footprint is XM, XP, XR, XB, etc. The die size is L, G, E, etc.
So XP-L and XM-L2 actually use the same chip (the L2), but one is in the bigger XM casing and the other is in the trimmed XP casing (you can see the 4 “slices” taken off the dome).
