Hm, but im still a bit sceptical about those 7500 lumens. Dont get me wrong, my order has already been placed for the XHP35 variant, but i havent seen any supplier yet delivering a flashlight with XHP35 and 2500 lumens. 2200 is more likely, which would make 6600 lumens total.
But everything is just speculation until you can do a measurement. I would really like to be wrong here! :partying_face:
EDIT: Ok, just to proof myself wrong, Acebeam K70 and Manker MK35 f.e. have more thank 2500 lumens, but they are single LED lights, not triple like the MT09R. :nerd_face:
The same was said about the 70.2 version and not only did it make the 15k mark it surpassed it at 16k... Remember the TA style driver so it is going to be driven almost as well as most aftermarket modded lights.
For the XHP70.2 - what is the stepdown after the 55°C / or a minute later - 5000lm or 1700lm? I mean - what is the sustainable lumen level for a longer period of time?
I am not sure exactly what the output is at the step down... I can tell you that the few times I remember it stepping down it was not a lot of difference. Maybe between 7k to 10k.. And even at step down you can kick it right back to turbo and continue to do that until the batteries are depleted or the heat is simply too hot to hold..
I forget which group mode it is but, one of them sets the light to top out at 5k lumen.... This was added for muggles and I do know that you can run it at that output continually...
From the emails and basically no one seems to know anything I do believe it is lost or destroyed.
This much later it really does not matter that much now as I will have a shipment of 70.2's arriving tomorrow I believe and sometime in the next week a second shipment which will have both 70.2 versions as well as 35 High versions... And I will still try as best I can to make sure footage gets posted as fast a possible,
Some of you may have your own by that time but if by chance they have not arrived I will be posting footage ass soon as that second shipment arrives.
I should have also said that once that first shipment arrives and I get them all inventoried into the system and each one is inspected and tested they will be available for sale on the stores website.
Thanks for the shots, the beam looks pretty tight. Any chance for a shot in a darker environment? We are all eagerly waiting for some images of the 35 hi…
