One respectable seller forget to ship out some parts for this project, so it is delayed :weary:
Can I order it?
Sure.
If you know what to do with them.
I will have some more suitable rings (existing positive q8 rings a too thick to use a pair of them in such config) soon, if you need them you can wait about a week.
BTW, if Im not mistaken I have contacted you with PM about solid brass tail boards. Still would like to know your opinion.
I can not express my correct meaning in English.
I’m sorry if I missed this in a prior post but, P60 solid Cu 18350 neck+S2+ Cu pill inside $25 155 g…what is this?
This is drop-in substitute. You can build full head and change them “on the way”.
Upd.
This set was made for quad build. But if you have shorter pill you can use single led with some optics or reflector.
Hi,
one of one Jaxman Mini C8 Quad. 4x Nichia D280, FET Driver and some GITD. Nice work!
Regards
Kenjii
Damn i’ve missed all the good quad spacer runs
I want an M8 quad!
Kenjii got full height pill for M8, not simple spacer.
Sure that works too. Take my money
I wouldnt make more of such pills. I can think about spacers, but not sure that M8 (with brass pill) is suitable host for this.
Is the full pill too difficult to make or too expensive to sell? I know the M1 had the expensive optics and machining but people seem to like the quad kits dont they?
It is too difficult to make by small quantities. I cant get calibration tool for threads when they are not standart size, so pill should be machined and test fit and then again machined etc. until it fits.
I dont feel M1 or M8 host suitable for 24mm carclo optics when M2 is available. It is smaller, available as bare host, and imo looks great, specially with gitd o-ring. I think M2 kit was 3 times more popular then M1.
So, convoy m2 actually looks like the perfect host for small quad.
Will make them if will get enough requests.
I have a 24mm carclo optics in my M1 that I built a quad XPL-Hi. The optics is a bit on the small side though. Could be possibly 2mm-3mm larger and then It would cover the edge of the home made copper heatsink I made, but it works fine.
Thinking about more M2 kits (does liner ring requires changes or no).
Can anyone else confirm same problems?
Note 1: In my suppose stock thin o-ring was placed between bezel and glass lenses. I recommend to save this in quad mod.
Note 2: More recent version have already had thicker GITD o-ring
Yes
M2 is the situation
Can you put stock o-ring between glass and bezel?
