Non Flashlight orders/received
Aha, a rangefinder (goggled the lettering).
Looked like a Klingon dog-whistle or something. :smiley:
Okay, a targ-whistle…
LMAO sorry.... It is a laser ranger finder.. I have wanted one for a while but any that go out to a decent range get stupid expensive... This one was not cheap but reasonable... And just from goofing off with it today reasonably accurate.
A new camera; Panasonic ZS100!
1” sensor, 10X optical zoom, Program, aperture or shutter priority, manual… An electronic viewfinder as well as the 3” display.
Nice Don. Let us know how you like it.
Nice! I see it’s an upgrade from TZ4. :slight_smile:
Yep, the TZ4 has been a faithful performer for almost 10 years; worn a little about the corners. :wink:
Almost $300 to get these tiny things CNCd:
Sure… But how are you going to obtain 1.21 GigaWatts?
He was banned? So he appears the same guy lamplight firefly which our comments become sick and sick
I thought he might have been LedBuy. Who knows? All I do know he was here to cause problems. I’m glad SB took care of it quickly.
By running water through it to cool it down :smiley:
It was just a matter of time :wink: Great thread by the way glenn! :+1:
Thanks pal! :slight_smile:
The dial indicator i received a few days ago from aliexpress didn’t work, not surprising after opening it and having a look, i’ll see if i can make a bushing to fix it :person_facepalming:
Looks like the shaft on the gear is broken
Check out the charge rate using the Dash charger.
As l posted earlier, l think OnePlus’ Dash charging is better for the battery than the usual lower rates. As l pointed out earlier, my battery gets more hot using the ‘normal’ rates than the Dash charging technology in my OnePlus.
l tried the lower, slower charging rates thinking it should be better but because the Dash charging technique has a special circuitry that routes back the heat to the psu, only the psu gets hot.
ln fact, l notice my battery’s performance is as good as when l first started using my phone, going into its 3rd year.
I like what I’m seeing. Notice that the battery was only 27.5 degrees C?. Just ordered the Dash car charger.
:+1:
One more personal technique of mine to prolong my battery’s cycle life is to avoid having the battery fully charged the whole night and instead just charge it the next morning instead since it doesn’t take long to charge it 80% using the oem Dash charging anyway.
It’s a well-known fact that a high SOC (state-of-charge) is detrimental to lithium-ions.
…and more detrimental is high heat situations.
