13583 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 4 min 5 sec ago
ToyKeeper wrote:
The ramp stops at the top and bottom. To turn around, let go of the button and then hold it again.
Nice! It will be manipulated according the user’s will! Thumbs Up
ToyKeeper wrote:
The top/bottom blinks were initially added as part of an auto-reversing UI, but I’m not sure they make any sense in a UI which stops on its own. It’s not generally hard to tell that it has stopped, especially at the bottom end. However, it can be difficult to gauge how far up the ramp the light is.
I suppose that Crescendo is the case you mentioned. I’ve been using it (and like it a lot!!! Thanks TK!!) in a modded light but the auto-reversing is a bit “awkward” specially comparing witrh the Emisar D4 UI. It takes longer to get used to.
This said, I guess that sometimes it is harder to see when the top is reached, not the bottom. And that was the reason why I posted C and D as my options. The highest luminosity seems harder to control or to “eye-measure” than the lowest.
I still think that the blinks make sense to avoid pressing the button like there was no tomorrow and to mark some points while ramping.
ToyKeeper wrote:
I configure mine with a blink at channel boundaries only. This lets me know if I should expect more than 8 hours of runtime, between 1 and 8 hours, or less than 1 hour.
This might be the only thing why I wold add the B mark, to know what to expect in terms of battery, as the highest regulation surely implies more drain than the 1st 7135 limit.
Still, so far I maintain my suggestion C and D.
Also, I have one question. Would the passage from full regulation to FET work as in the Emisar D4, meaning: after passinf that limit, and depending on the use LEDs that will be used, is it probable to see a “tint shift”? I have the D4 with XP-G2 S4 3D and I experience that “shift”. Don’t know how others react, and also don’t know it is supposed to expect that change on the new setting, after the regulation passage.
Please ignore my question if it is nonsense Innocent And thanks again for the work done so far.
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
joechina
Last seen: 1 month 5 days ago
I want all blinks.
A
B
C
D
What I find interesting from the runtime table:
You gain 2h runtime if you go from 65 down to 62
Quote:
62: 141.8 lm, 315 mA, 10 hours
63: 148.0 lm, 329 mA, 9 hours
64: 153.7 lm, 341 mA, 9 hours
65: 160.0 lm, 355 mA, 8 hours
Can we have the default level for power on set to level 62, please?
I dont think someone see a difference between 142 and 160 lumen and the 2h more seems to be a good trade-off.
joechina
Optical programming seems the most promising. But a lot of work and time.
I want that in a later premium edition of the FW3A with 90 CRI Nichia LEDs Smile not now
A sunrise mode, please no. I think it’s to hard to set with the lamp. And the µC cant sleep.
Leave room, it’s already feature packed.
Persechini
Persechini's picture
Last seen: 6 months 1 week ago
Optical programming seems amazing!
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
joechina
@TK
one thing for the flow chart:
If you print it on a b/w laser printer you can’t distinguish the green and black lines very well.
Mabye if they are fatter?
A direct label on the lines maybe work
—x1—>
—h—>
—x1+h—>
mayby other lines
ToyKeeper
ToyKeeper's picture
Last seen: 13 hours 31 min ago
Yes, but the effect isn’t as pronounced. This shows roughly what kind of tint shift to expect on three types of drivers.
ToyKeeper
ToyKeeper's picture
Quote:
62: 141.8 lm, 315 mA, 10 hours 63: 148.0 lm, 329 mA, 9 hours 64: 153.7 lm, 341 mA, 9 hours 65: 160.0 lm, 355 mA, 8 hours
With more digits shown, it’s not such a big difference:
62: 9.52 hours
65: 8.45 hours
The script rounded to the nearest integer, since the values are all approximate anyway.
Just a Guy
Last seen: 1 month 2 days ago
Please add my name to the "interested" list for one light (first request).
ToyKeeper
ToyKeeper's picture
joechina wrote:
one thing for the flow chart: If you print it on a b/w laser printer you can’t distinguish the green and black lines very well.
Hmm, I’ll keep that in mind in case the diagram ships with the light. For now though, the .svg file is in the repository, and should work in Inkscape (free, runs on several OSes).
mts49
Last seen: 1 year 3 weeks ago
Do we have a current photo of the external design as of now?
Target production date or release date?
Tixx
ToyKeeper wrote:
Blink option running vote tally…
As a reminder, the options are: (where in the ramp to blink)
  • A. Floor
  • B. ~150 lm, level 65/150
  • C. ~1000 lm, level 130/150 (highest regulated level)
  • D. Ceiling
Totals:
  • A: -7
  • B: 3
  • C: 14
  • D: 3
19 votes:
I’ve been saving each vote as sort of a trinary variant of Approval voting… capital letter for +1 point, lower-case letter for +0, letter omitted entirely for -1. Originally I had planned on doing regular Approval voting, but Pulsar expressed a lukewarm opinion about option C so I added a state between “approve” and “disapprove”.
Not sure I’m familiar with negative voting. Can you just run raw numbers of for an option next to it? Also if people cannot stop at B and C, what will it accomplish? And force stopping would not be desirable I don’t think.
BT100
Last seen: 14 hours 7 min ago
Hi. I would like to be put on the list for 1. Thanks
Tixx
The top/bottom blinks were initially added as part of an auto-reversing UI, but I’m not sure they make any sense in a UI which stops on its own. It’s not generally hard to tell that it has stopped, especially at the bottom end. However, it can be difficult to gauge how far up the ramp the light is. I configure mine with a blink at channel boundaries only. This lets me know if I should expect more than 8 hours of runtime, between 1 and 8 hours, or less than 1 hour.
None of the options should be an issue for anyone with firmware flashing tools, but I hope to make the default agreeable to as many people as possible. So far, it sounds like that means option C only, a blink at the highest regulated level before the FET kicks in. That also happens to be where the ceiling is set by default, which would mean it has a blink at the top of the ramp unless the user changes the ceiling level.
Since there’s also a configurable stepped ramp which can be used to consistently reach precise levels, I’m leaning toward relatively few blinks. Set your preferred floor, ceiling, and number of steps, and it’ll give you a mode with evenly-spaced levels (plus turbo, if not already in the ramp). For example:
  • 3 steps from 20 to 130: 11 / 240 / 1100 lm (plus turbo)
  • 4 steps from 10 to 130: 3.3 / 84 / 394 / 1100 lm (plus turbo)
  • 5 steps from 3 to 150: 0.8 / 47 / 246 / 741 / 3000 lm
It can be whatever you like.
Those abilities seem cool. Getting to look like a custom guppy driver custom output settings like
JasonWW
JasonWW's picture
Last seen: 8 hours 15 min ago
I think people have forgotten that you can ramp both upward and downward. As you ramp down, you see the blink and you release the button. Done.
Tixx
True, so you have to either pass it from low to high and stop and ramp back down or start ramping from above.
varbos
Last seen: 6 days 9 hours ago
Put me on the list for one please.
wellerus
Last seen: 7 hours 25 sec ago
I’m interested for 1 piece, so please put me on the list.
gravelmonkey
Last seen: 1 day 4 hours ago
Using my D4, I don’t feel it has to be perfectly on the blink. I like the reference point because the human eye is terrible at judging brightness-
I frequently can’t tell if my Skilhunt H03 (last mode memory) is on medium (70lm) or high (160lm) until I cycle through the modes. The difference in modes is 10hours vs 5 hours runtime.
ToyKeeper
ToyKeeper's picture
Nope, not yet.
DB Custom
DB Custom's picture
Last seen: 2 days 3 hours ago
As far as missing the channel blink, it could be programmed to stop there instead of just blink, then a new press would continue on in the ramp. But then, that would interrupt the ramp and all sorts of other issue. I don’t mind passing it going up then getting close coming back down, it means the lights output is just shy of maxed out on the 7135 chip so regulation is good. Stopping just over the blink of course has the FET engaged and you’ve entered into not-so-efficient territory. AS IF this were critical. In critical situations a spare cell should be readily available anyway, right?
So, I like the blink top and bottom, and the blink at the channel change. Where in the soup does that put my preference? Wink
ToyKeeper
ToyKeeper's picture
Out of curiosity, I tried making the smooth ramp blink every time it passed a stepped ramp level. This would make the number and placement of blinks configurable… but in practice it was mostly just annoying. Then again, the default config had 7 steps.
pepinfaxera
Last seen: 3 hours 17 min ago
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
pepinfaxera
Interest list … The Miller … pepinfaxera
588 … darrylo
589 … darrylo 2nd
932 … darrylo 3nd
933 … darrylo 4nd
246 … robbobus
941 … robbobus …
942 … robbobus …
. 17 … Ozythemandias
411 … Ozythemandias
289 … BeardedRaleigh
578 … BeardedRaleigh
943 … BeardedRaleigh …
944 … BeardedRaleigh …
362 … Gj
413 … Gj
414 … Gj
415 … Gj
772 … Gj
391 … shilent
773 … shilent
…… … Agro … Edit: Not yet registered
332 … thebaum
999 … thebaum … 2º nd?
…… … Meyer … I do not see him registered
…… … TLF nº 221
…… … khas … I do not see him registered
Post #1309
pepinfaxera
Interest list
See Poost # 182
khas wrote:
Put me down for one please.
Any plans for a 18500 tube Innocent
khas: The Miller has not included him in the list
See Post #1309
d_t_a
Last seen: 6 hours 58 min ago
ToyKeeper wrote:
Last time I asked, there wasn’t much consensus on how muggle mode should work… so I went with the simplest option. That can change, if people want it to. Some options:
  • Dead simple style: On/off only, ~150 lm. <— current option
  • Traditional style: Low/med/high/off sequence, 10/80/300 lm.
  • Training wheels style: Simplified smooth ramp, 5 lm to 300 lm.
About another mood mode, I don’t have anything particular in mind. But if someone has a good idea, maybe it can happen.
I’m not sure if there’s enough space left for optical programming or not. It’s definitely the most work out of the things I mentioned, and I’d need to physically modify this FW3A prototype in order to do the development. Perhaps after the second prototype is made, I can turn the first one into a dedicated development host. For now though, I need it intact for thermal testing.
I don’t like “traditional” style as muggle mode. So either “training wheels” or “dead simple”. I suppose “training wheels” should be simple enough to learn about after a few minutes usage, so I’d more likely go for “training wheels” muggle mode.
Minocc
Minocc's picture
Last seen: 43 min 16 sec ago
I would like to see blinks at A, C, and D. I like those blinks on my D4, and how I describe the brightness to people depends on the middle blink.
off
Sensible Bright
blink
Stupid Bright
blinding
Tender
Last seen: 1 year 2 weeks ago
ToyKeeper wrote:
Tender wrote:
How do the steps work? Does it pause at each step?
It works the same as the smooth ramp, except it only uses the configured steps, and each step is held for about 0.4 seconds. It’s similar to an Olight Baton interface, plus the ability to go down instead of only up. If the button is held, it will keep ramping until the user lets go or until it hits the end of the ramp.
BTW, I’m not clear on what your vote is now. It was AD, but now it sounds like maybe C or None?
I would say none. Keep it as smooth as possible. By default it stays in regulation, which would be where, I assume, most people will use it at. There’s always double click to turbo for when needed
"Keep On Luxing" © and "May The Lumin Be With You" © (by my very self)
steel_1024
steel_1024's picture
Last seen: 2 days 5 hours ago
Vote B, C
Muggle 3 level is good.
L-M-H no memory.
Sorry for my poor english.
gravelmonkey
I like the 5-300lm ramp muggle mode. If they don’t hold the switch, then they’ll never know it’s ramping capability and it will behave as a single mode.
Is muggle mode retained through cell changes?
ridasrich
Last seen: 8 months 6 days ago
1 please.
Looks fantastic and would give my HG2’s a proper workout.
My first post too – hi to everyone in BLF.
