What did you mod today?
What does it mean?
And how have you manage to trim switch boot?
The “firmware” for this flashlight has Next Mode Memory. Every time you turn it OFF it remembers what mode it was in, next time you turn it on it skips to the next mode, very annoying. It can be forced to quickly forget by tracing a pencil lead over the capacitor that holds charge to the IC.
I didn’t mod the switch boot, but the switch itself. I just cut enough off to clear the barrel(?). When that wasn’t enough to clear the switch boot, I put a ring of Venician Blind cord between the boot and the lip it sits on. Hope that helps!
Nice mod as a first published one WARvault. :slight_smile:
I like that flashlight, I have one from when it was still Ultrafire branded.
WARvault, thanks. Nice mod :slight_smile:
Hi and welcome WARvault. You come from a nice area. I went to a school camp there around 1975. I guess things would have changed a little since then. Nice mod. :beer:
BLF A6 driver into a Convoy C8. This simple mod took me about 15 minutes.
…and you got instant improvement in user interface and output :slight_smile:
The C8 is a better light with the A6 driver.
I did the mod for the user interface. FET was a bonus.
That’s why I prefer Biscotti driver… 3A regulated output and customizable interface.
Simon’s drivers became my first choice some months ago for any simple light (S2+, C8, any tail-click li-ion only light…)
Maybe you know then if the biscotti drivers that Simon sells at this moment have the corrected firmware? I have been waiting for a year now for confirmation of that.
My C8 came from Gearbest with the old 3/5 mode firmware.
I saw that Simon is selling drivers with Biscotti. — shrug — I made a choice.
I’m pretty happy with the C8 with A6 driver. Don’t see any reason to change it.
Jos, do you have any info on what should be corrected?
I bought one driver with Biscotti from bg last year for an S2+, the UI is much better then the 3/5 mode and still regulated :wink:
What should be corrected ? I don’t recall of any problem ?
The first batch of biscotti drivers had something wrong in the firmware (a ‘fuse setting’), making the PWM frequency twice too high, and also the timings of any events in the UI. Getting into program mode was difficult, and maybe the modes were affected too, can’t remember. Annoyingly, because superficially there seems nothing wrong, Simon kept selling those drivers and putting them in his lights. Even the desert tan S2+ that came out half a year later have (sometimes?) drivers with wrong firmware. He may even never corrected the firmware? I don’t know because it can’t be found on Simon’s site and no one ever took notice again. I just know that I really want a stash of biscotti drivers but only if it has the corrected firmware (I can not re-flash drivers).
The ones I bought were easy to use, all of them were 8*7135 if that changes anything.
No problem getting in config mode, nor setting the correct group.
I didn’t see any complain about them, so I would guess that it’s gone now ?
But Simon sells biscotti drivers with less chips too, there may be some left of those with wrong firmware. I can get answers in the form of ‘probably’ and ‘mine seems fine, bought then and then’, but a year ago i bought 12 drivers, all with wrong firmware, and I would really like to be certain if I buy 10+ drivers again.
I totally understand that…
Sorry, I can’t help you more than saying “mine are fine…”
I just looked on Simon’s site,and there is a 7135x3,4,6 or 8 driver with ‘new firmware’.It has the ui map,so i presume it is Biscotti.Convoy .Hope it’s the right one.
It is ‘new firmware’ as in: now biscotti firmware vs formerly the 3/5 mode firmware. But it does not mention the fixed vs non-fixed biscotti (because that would imply that there was a non-fixed biscotti for sale before which does not look good as a seller). I think that Simon decided that the firmware with wrong fuse-settings was good enough, and at that point it is essential not to mention anything wrong.
I bought them from BG (8x 7135) and had to wait several times when they were out of stock.
How do i figure out if i have one with the wrong software fuse?
