well it was unintentional, i have that blue by coincidence.
The voltage meters is somewhat dissapointing, mine reading 4.05v while the real value should be 4.2v charged using ISDT SC-608 and also confirmed with my multimeter.
Yes there’s an error in the voltage reading. Fortunately it’s nearly constant so you can correct it easily. For mine it was 0.15V near full charge and 0.17 at lower voltages, say from 4 downwards.
So, what is the word on the DT70? Are there later batch version that are more reliable? It's one of the lights I have been eyeing for quite some time now and I am still thinking of getting one. From what I hear, it is a gamble though if we get a dud.
So I should ask the sellers if they have the updated version with coil springs then. From what I read, turbo mode does not last very long at all before stepping down to 2800lm so that is something I should consider too. I also have to ask myself how bright before a flashlight is bright enough! I'm still amazed at my L6 and really, that should be enough light for anything I would ever need other than showing really.
I don’t think this is necessary because they stopped selling the old ones and all the current ones use springs. This change was several months ago. I guess you could verify it if you wanted to.
I usually buy lights of ebay and make them an offer for a good deal, but you just never know what the sellers are selling so I may as well ask them. I got two Nitecore EA81's for a real steal on ebay and they are top notch.
The Astrolux MF01 at $80 is quite impressive. I think the xpg2 version measures 12k to 13k lumen. The best part is if the driver fails, it can be replaced by an aftermarket Texas_Ace fet driver running NarsilM from Lexel which boosts output to about 18k lumen! The Nichia version is a few thousand less lumen on turbo but thats because it’s not as efficient.
The big difference between the MF01 and the DT70 is the beam shape since the MF01 uses tir lenses and has less bright spill lighting.
Haikelite also just had a Group Buy on their new MT09R which is a reflector style light using 3 x 70.2 and a Texas_Ace based driver with ramping. It’s not using NarsilM, but it’s similar. These put out 15k and were costing $125.
Thanks Jason, I'll have a look at them all and see what looks good. Appreciate the help on this!
I was hoping for lights that could use protected batteries. Had a look at the Astrolux MF01 before but specs clearly state unprotected batteries but it really looks good.
You would need to swap to different springs in the carrier to fit longer cells. Some people have done that to fit protected cells. Maybe cutting them shorter would work? You just need to reduce their collapsed height.
Keep in mind this light draws a lot of amps so you need good cells with protection circuitry that can handle at least 5A to 6A 10A each.
Are you sure about this? I thought max current was more like 9A or so.
Edit: nah, quick calculation resulted in closer to 6A. (I used to calculate using specified 12000 lumens, now I took 9000 lumens for 219C, which results in this difference)
Let me think. Lexel tested 16A, but I believe that was at 8v, right? It’s a 2S2P battery carrier. So with 2 cells that’s 16A each. 4 cells would be 8A each.
Yeah, I was wrong earlier. I was thinking 4A each and 5A to 6A to give some overhead. Now I see it’s double that. So you would want protection circuitry that can do about 10A per cell.
So probably the GA or MJ1 from Liion Wholesale or the GA from MTN Electronics. There’s not too many protected cells that can do 10A.
Based on this I would not call the MF01 “better” - it’s different and will not go as far as the DT70. And as written, based on the actual prices it’s also not cheaper…
I don’t know if your trolling me or if you’re being serious.
Firstly, the DT70 sells for about $170 and the MF01 about $80. So…
Secondly, the MF01 is rated at 450 meters throw. The DT70 is rated at 700 meters. I don’t know why those pictures show them looking so similar in throw. Either the DT70 is weaker than it should be or the MF01 is stronger than it should be.
If you are looking for a light based on throw, there are better options.
Do you really not understand the beam characteristics between the tir and reflector?
If not, I will try to summarize. The TIR gives you weaker spill lighting, but a stronger hotspot. Typically the hot spot is larger in diameter than a reflector. By the same token, a reflector based light is going to give a stronger amount of spill lighting and a more focused hotspot. This typically equates to a longer throw distance. The pictures you posted show this to be true. Look closely and you can see that the MF01 has a hotspot about twice the diameter than the DT70.
Going back to why I said the MF01 was “better” is mainly because of price and their similar lumen output. I do point out that they have different beam characteristics so you have to keep that in mind and choose what’s best for your needs.
I know you like to argue with people and I don’t want to get caught up in a back and forth situation with you. I was merely suggesting some better alternatives (in my opinion) to the DT70 for klrman. You don’t have to listen to me. I’m no authority, I’m just trying to help.
