BD04 is a zoomie. I’ve wanted one for a while but haven’t pulled the trigger.
The SupfireA2 is good but you need to do LED swap. The driver with blink modes is difficult to swap because of the integrated charging, but not that bad because with no mode memory, you just turn the light off and right back on to avoid strobe.
If size is your #1 criteria and you are willing to mod, the smallest cheap 18650 zoomie I’ve found is this Skywolfeye on Ebay. Pretty compact at 110mm x 26mm (I just measured mine).
If you are not in a big hurry , I have one of the NEW Wowtac (formerly Atactical) zoomies coming for review in the next few days ($19.95)……should have the review up by about the middle of this month (a week or so from receiving the light)
This one looks a lot different than what I am used to in a zoomie though , side switch operation and TIR optic being the big differences and comes with the 2600 mAh USB rechargeable cell for the price. Also hidden strobe and turbo from any mode.
Kind of excited to get my hands on this one really. So far I have reviewed several of their lights and have been impressed with the quality you get for the price of the lights.
It’s rated at 1000 lumens which I would agree with. It throws farther than my Nitecore P12 and when both are compared on a white wall the A3S in full zoom will drown out the P12. Also the A3S is about half an inch shorter in length with the head of the light extended all the way, so it’s relatively compact. Using the zoom is very smooth and somewhat air tight so you get a nice sealed feel to it. The beam at full flood is great with no noticeable artifacts and they designed the focal point so that you don’t get the square led effect like most cheap lights. I definitely recommend it.
2018-02-13 16:57 ISC CHICAGO IL (USPS), Processed Through Facility, Your item has been processed through our facility in ISC CHICAGO IL (USPS) at 4:57 pm on February 13, 2018.
2018-02-03 10:28 Origin Post is Preparing Shipment
2018-02-03 10:28 CHINA, XIAMEN EMS, Processed Through Facility
