Oh YES! :partying_face:
Before the mod i was measuring barely 8k lumen - on a rough conservative ceiling bounce/luxmeter test, now itās 13k+ at startup.
It remains to be seen how it handles the heat and current over time. I donāt plan to torture test it. Iām just glad to have the extra power. Iāll certainly be cautious using turbo.
Edit: looking at the picts iām wondering whether something is biasedā¦ That MF-01 shot seems too over exposed compared to the Q8ā¦ Iāll shoot them again.
Any discount codes left for this? I am a member over at M4DM4Xās site, but the codes there donāt work.
also, all the old codes freeme has sent months ago are now invalid. Anything left?
If so, would like the XP-G3 version, and send codes!
hiKARInoob, did you measure those values? So V2 is dimmer than V1? I just received my MF01 219c today so Iām assuming it is V2. Itās smaller than I expected and the tint is slightly less yellow the the 219c on my S42.
Ceiling bounce using the Meteor M43 as a reference. The beam profiles of M43 and MF01 are close to identical, so I believe absolute lumens are sufficiently accurate. Max output is also in concurrence with measurements of other members Iāve read.
Since V1 and V2 have identical beam, relative output is correct. So in my case V2 is slighty less bright than V1 with full cells, but V2 maintains higher output with depleting cells. Both are 219C.
I was just playing around with my new MF01 and after awhile, when I enable Turbo mode, it just turns off randomly and goes into lockout mode. I would have to hold the button 2 sec to unlock it. It happened several times. The batteries are VTC6. Itās not fully charged but the light indicator is red so that means thereās still charge in it.
Does MF01 have any protection mechanism that turns off and enters lockout mode under turbo mode when it overheats or battery voltage not enough?
