Can I quote you.
One word: Reaver.
Even script kiddies can do it.
Your wifi is there, stationary, ain’t going anywhere. Whether it’s a creepy neighbor kid wanting to grab pr0n without mommy and daddy finding out, or someone who’s wardriving and wanting to stick someone else with the blame for grabbing movies/music off the web, all it takes is to break the password once, and then you might as not even have one.
When you have multiple devices (laptops, tablets, phones) all connecting to your wifi, it’s a big pain in the ass to change the password on each and every one of them, let alone on a regular basis. So you don’t. Even once per month, an annoyance to you, is no big deal for someone to just park and run Reaver for a while, or a close enough neighbor to just run it overnight in comfort. And then it’s open-season once again. And you often can’t even tell if someone hacques in successfully, until a month or two after, when you get yet another nastygram in your inbox.
So it’s not just an “excuse”, it’s quite legit in many cases.
So, ironically, a good “defense” might very well be, “Hey, I got a vpn with max-level encryption, the dead-man switch enabled, ZERO traffic going in or out except through the vpn, so if someone thinks an illegally-DLed movie came to my account, IT AIN’T BY ME!”.
So vpns have very legit uses.
Ummm, you just did, no?
I use a VPN. I have to disable it when I want to stream videos on Netflix. I’d be happy to disable it here as well.
I have a TOR Relay and OpenVPN install on a RPi B (w/ 512mb RAM)
Soon to be upgrading to and Orange Pi Zero (quad core, 512mb RAM)
I stream netflix no problem thru my VPN
What I want to do is create an “open wifi” but QoS restrict it down to say 1Mb (mega bit) each way…then use IP Tables to route all traffic from that router thru the TOR network…this way they can browse all they want and anything they do nefarious won’t come back to me…
more or less make it more enticing to jump on an open network and leave my encrypted stuff alone
If people are using TOR to attack/troll the forum…shut em down
I consider myself a complete computer noob, but Tor is related to torrent or not?
No it is a system to hide where you are connecting from. Tor is an acronym for The Onion Router.
I wouldn’t be happy to see it blocked. But at the same time I wouldn’t oppose strongly because I don’t use it here.
[quote=WarHawk-AVG]
+1
If it is a small surgery, but a great cure, go right ahead with it.
I find it amazing that people would go to that extend to troll in this forum… You might think that using VPN or switching to mobile data would be enough… but TOR?
They aren’t going to any extent at all. Tor is exactly as easy to use as any other web browser.
Blocking Tor sounds like the least worst option.I have NordVPN but am too lazy to use it most of the time.I have to dissactivate it to visit Banggood.
I love where discussion is going. Lot’s of good tech talk, knowledge, and advice.
(Altruist consideration)
SB, how many instances were there of trolling via TOR? You could be blocking a segment of people who come here for information but aren’t signed up as members - (I lurked for a while before I signed up [not using TOR]). Perhaps it be worthwhile to parse the good from the bad (TOR) general traffic just not to shut people out.
(Business consideration)
Another way to look at it: Yes there is problematic traffic. But, you have ad space, which are click/site traffic dependent (that’s an assumption). How much headache/work hours are you saving for the loss of potential click/traffic revenue?! Therefore, you may want to analyze you overall traffic to find that out.
Anything to keep the trolls under the bridge asleep
Cheers David
It's fine with me if BLF blocks Tor, though I will miss the entertainment that some trolls provide.
My experience of trolls from running forums in the past is that they can get around whatever blocks you make. Too much free time on their hands.
If you block one VPN they just use another. Or they post from Starbucks or whatever. They get entertainment from the idea that they are ‘pissing you off’ and making you take futile steps to block them.
Best to just ban & ignore. Don’t give them the satisfaction of knowing they are annoying you and eventually they will go away.
I would say block it for the sake of stopping trolls keep coming back.
Pretty much all other forums I am using do not allow new user registration or forum use from tor networks. It is the new way of dealing with adverse elements.
Hi Tender,
Countless instances of trolling, and literally 100% of them use Tor. (Or maybe it’s 100% of “him”. )
This is indeed a valid concern. I’ll try to dig through the logs a bit more. But at least based on anecdotal evidence, I suspect it will be an extremely minor change. I’ve often noticed that the first time a user comes around BLF and registers, they usually don’t use Tor. Then, as they start trolling and/or receive warnings from me, they switch to Tor.
My experience of trolls from running forums in the past is that they can get around whatever blocks you make. Too much free time on their hands. If you block one VPN they just use another. Or they post from Starbucks or whatever. They get entertainment from the idea that they are ‘pissing you off’ and making you take futile steps to block them. Best to just ban & ignore. Don’t give them the satisfaction of knowing they are annoying you and eventually they will go away.
Thanks, you bring up an extremely important point here. I still think that eliminating Tor would be like eliminating the low-hanging fruit. But whatever is decided, the more fundamental issue is what you mentioned here. Some BLF members are still engaging the trolls far too much, which is why they keep coming back. If you just leave them yelling like the crazy fools they are in their own little echo chamber, they'll leave us in peace and go cause trouble elsewhere. Hence these points that I repeat ad nauseam in public and in PMs:
4. Please avoid fighting. If you or somebody else is losing their calm, please drop the subject.
Please also remember that one of the valid reasons to use the Rude! button is when a user is being conflictive. This includes starting, engaging in, or otherwise responding to arguments. The best way to stop an argument or make somebody stop trolling is by completely ignoring the post(s) and using the Rude! button when warranted. Also, please do not quote other users’ rude posts, since doing so only gives additional publicity to their rudeness.
Whatever makes life easier for sb is my choice. While it is true blocking the use of Tor won’t halt all spam or trolling, if it makes it easier for sb to keep BLF clean then that is what he should do. It can be quite a challenge to keep a forum like BLF clean and easy to use for all us normal flashaholics and keep out the riffraff.
Wasn't aware Tor could be blocked. But just googled it, and learned something. Apparently most Tor exit nodes can be blocked, but it's not 100%.
