Where do I sign up for this one??? Looks interesting!!! :heart_eyes:
That’s what i’ve been thinking about. 4*18650 will be always enough for a XHP35 Hi.
I think 8 cells are kind of waste.
I want one
GT + this = one for each hand
You don’t need to use 8 cells in the GT.
The long battery tube is for balance as i understand.
I plan to leave one carrier empty.
8 cells were never about the need for them with an xhp35. It was about balance. The short tube version is horribly unblanced and literally hurts your wrist to hold for any length of time.
Not to mention it looks silly.
AllenT: RobertB:Martin, what light is this? Someone posted it on flashlight fanatics
I see. That’s what the long tube for.
I agree. The only have experience with the long tube but the short seems like it would torque the wrist a good bit.
Because that’s what I would do to kill the GT 130mm Reflector! :+1:
Definitely Mateminco/Astrolux, same tube and head machining as MF02.
KawiBoy1428:Because that’s what I would do to kill the GT 130mm Reflector! :+1:
So it’s module design too. There must be dual heads for this one.
Can’t wait to see the dual heads of two big heads.
Interested ! Thanks
Interested nw
If you guys want the picture to show up in your qoute, just add a space before the end qoute. Like this:
—-imgur.com/JWKij5R.jpg! [/qoute]
Or this:
[/qoute]
Iam interested too.
Thanks a lot!
Interested
Interested!
the GT development was noticed by the other manufacturers as well…
i was told they planned to stay quiet until the gt groupbuy is finished because they do not want to interfere.
someone did not.
I have known it for over 2 weeks just that this light will come
Same for me I was told not to tell anyone else about BG/Matemineco is going to bring a GT pendant
You can likely put a MF01 head on the other end for balance
Is it should mf1>mf2>mf3>mf4 (quality)?
patmurris:Different/better led - more output… more throw…? Just a question…
Better LED is relative.
Toss a Flat black in the GT and it should do around 2Mcd.
Or toss an XHP70.2 and it does ~8000 lumens with ~1200m of throw.
The only real option that will net you gains in both throw and lumens is the sst-90 or whatever it is. BUT that LED costs around $150 for the LED alone. So gonna guess they are not using that lol.
$150 for an LED ? That is nuts.
TA sst-90 100$ ??? are you sure? I see 30 bucks
https://www.ebay.com/itm/30W-SST-90-SST-90-Warm-White-3000K-Led-Chip-Light-Lamp-Blub-3-2-3-6V-9A-/202172841863
