BLF GT custom handle bracket kit. (DBCustom approved. Post #121)
149 posts / 0 new
southland
southland's picture
Last seen: 2 months 4 weeks ago
Looks like a Delrin bracket.
weklund
weklund's picture
Last seen: 17 hours 28 sec ago
Interested … nice.
... Happy Landings ...
DB Custom
DB Custom's picture
Last seen: 7 hours 3 min ago
It’s actually raw G10. The stuff you normally see as knife scales? Only much thicker. Raw meaning no attempt to color it was made when it was produced. We’re used to seeing black, even a few colors these days… recently even some knife scales in the jewel hued light green of it’s raw state. It’s a high pressure laminate fiberglass/epoxy material that is extremely dense and stable.
I’ve got a few 12” rounds that are over 2” thick, they’re heavy! lol
I’ve had it for 20+ years, it was actually a 16” square sheet 13/16” thick with a hole in the center and drilled/tapped holes for mounting the machine that does the surgical procedure of knee replacements. I cut out a square on my table saw, then used an end mill bit in my table top drill press to get an L bracket shape. Sanded it to profile on my belt sander, finished sanding by hand.
teacher
teacher's picture
Last seen: 1 year 1 month ago
Turningbluechips…… what’s happening with the V2 Prototype?
Looking forward to it!!! Still very interested……. Thumbs Up
Turningbluechips
Turningbluechips's picture
Last seen: 1 week 18 hours ago
Life got in the way. Been a busy couple weeks bouncing around from shop to shop trying to get a new job up and running then my boiler decided to take a crap on me last week. I have the V2 programmed save for a couple minor tweaks. I hope to get something cut out this week to send down to Texas for some Dale testing and approval.
DB Custom
DB Custom's picture
Oh YeaH! Big Smile
teacher
teacher's picture
Ok… thanks for the info. Sounds good…… Smile
Feel free to cut out two & send me one to test.
I am sold on your design, handle & all. That is what I want to test. I’m not interested in changing anything.
Have money… will send to defray costs. Let me know. Thumbs Up
Turningbluechips
Another note. Be on the lookout for a giveaway of the V1 prototype. I should get a chance to make a post for it later this evening.
Hardware
Hardware's picture
Last seen: 2 years 5 months ago
DB Custom wrote:
It's actually raw G10. The stuff you normally see as knife scales? Only much thicker. Raw meaning no attempt to color it was made when it was produced. We're used to seeing black, even a few colors these days... recently even some knife scales in the jewel hued light green of it's raw state. It's a high pressure laminate fiberglass/epoxy material that is extremely dense and stable. I've got a few 12" rounds that are over 2" thick, they're heavy! lol I've had it for 20+ years, it was actually a 16" square sheet 13/16" thick with a hole in the center and drilled/tapped holes for mounting the machine that does the surgical procedure of knee replacements. I cut out a square on my table saw, then used an end mill bit in my table top drill press to get an L bracket shape. Sanded it to profile on my belt sander, finished sanding by hand.
Thank you very much
contactcr
Last seen: 7 hours 27 min ago
Now you just need to find room on it for a quick detach swivel and 2nd tripod fitting to replace the one you are using for the handle! (mostly kidding)
Turningbluechips
!{width:30%}https://media.midwayusa.com/productimages/880×660/Primary/768/768028.jpg!
That’s in the works right after I get the heated grip and massage options worked out. Lol.
contactcr
So a heavy copper plug that connects directly to the MCPCB, smart!
Turningbluechips
I’ll update the OP with more pics over the weekend. It’s friday evening and I’m going out for a few beers. Beer
teacher
teacher's picture
Looking good!!! Enjoy the cool ones…. Beer . Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 12 hours 59 min ago
Looking good Tbc. Beer
ARsee
ARsee's picture
Nice!! Thumbs Up Beer
Count me in. One for sure.
Possibly two
Nav88
This looks like a nice utilitarian design. Button accessibility is a very nice feature.
Have you considered adding a partial-depth cut (maybe need a mill instead of waterjet?) on either side of the curved beam section, tapered off before the ends to keep the mounting features intact? It would give the beam a t-shaped cross-section with the cross of the t towards the light. That would remove a bunch of material and keep most of its strength. Maybe also give it a more finished look, depending on taste.
What’s the purpose of the short link with countersunk holes? So you can adjust the position of the handle relative to the light?
ETA: larger inside corner radii leading up to the boss with the counterbore where you screw to the light might look a little sleaker.
Turningbluechips
Profiling is 100% not happening.
The short link attaches to the GT mounting bracket and a handle or grip would mount to it like the 5/8” bar did on V1. Its countersunk on both sides for a 1/4-20 flat head socket screw, making it ambidextrous and adjustable.
And then he calls me out on the part I cheated on… The boss made it easy for me to make the mounting hole for the first one. I have a setup part now so that could be cleaned up for sure. A taper with a .750” radius top and bottom would look good I think.
ARsee
ARsee's picture
Attractant.
Nectar of the flower to the bee.
Turningbluechips
I should probably test fit this thing with the V1 “grip” before it gets sent off to gi.lumens in the morning. At this point I can only assume the bracket fits the light…
teacher
teacher's picture
Wow…… I think you nailed it!! Wink . Thumbs Up
Muto
Last seen: 8 hours 54 min ago
Nice !!!
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
DB Custom
DB Custom's picture
Got the samples in today, pretty dang cool! The access to the switch is perfect, or can be easily tweaked to suit ya…
Took too many pictures, bear with me… Smile
These were apparently tumbled after being finished and it’s a nice look, I lined the inside of the bracket with a strip of black electrical tape, shaved the tape off on the sides to make it match the bracket, it fits on snug and protects the anodizing. All in all very well done and extremely useful.
I have some Titanium tubing I may use to make another handle, thread inside for a plug and thread the plug for the mount, should work and be strong and light weight. Wink
Highly recommend this one, robust and plenty strong enough to not have to worry about. Smile
teacher
teacher's picture
Looking very good TBC…… Thumbs Up
goshdogit
goshdogit's picture
Last seen: 4 hours 48 min ago
Wow! Nice work, TBC! Thumbs Up
I like the easy switch access, and the ability to tweak the handle side to side. Great solution to suit righties and lefties.
Excellent pics, Dale! And plenty of them! Wink
Turningbluechips
That’s why you send stuff to a professional photographer… yes they were tumbled Dale but not nearly as long as I would have liked.
ARsee
ARsee's picture
TBC, what do you think, are these necessary to aid locking position of the handle and short wishbone?
Pinning with a stainless roll pin after adjusted Thumbs Up
DB Custom
DB Custom's picture
Sorry guys, I hadn’t used my 1DsMkII full frame Pro body in a while so I stuck the Hybrid IS 100mm Macro on it and had a bit of fun. Big Smile
There are things that could be done to fine tune the aesthetic’s of these, but none of it would make it work better and it’d just gobble up a lot of time making them much more costly so right here where they’re at is plenty sufficient and they look nice, work beautifully.
Turningbluechips
ARsee wrote:
TBC, what do you think, are these necessary to aid locking position of the handle and short wishbone? Pinning with a stainless roll pin after adjusted Thumbs Up
You could pin it if you wanted I guess but it won’t move without some abuse. A drop of blue loctite on the joint would provide ease of mind if one was worried I guess.
Turningbluechips
Well put sir. The only change I can foresee is blending in the boss for the mounting screw which will cost nothing. It looks like the only thing left to do is a time study and to lean on the boss for a good price. Then the fact that I would need to come in on my own time as I now have at least a month worth of work that is needed by Feb 12. When I can make some time I think I want to make a small batch of just brackets (let’s say 20) and see where it goes. Anybody with a drill, a #7 drill bit and a 1/4-20 tap can make about anything a handle.
