Nice!! :+1:
Count me in. One for sure.
Possibly two
This looks like a nice utilitarian design. Button accessibility is a very nice feature.
Have you considered adding a partial-depth cut (maybe need a mill instead of waterjet?) on either side of the curved beam section, tapered off before the ends to keep the mounting features intact? It would give the beam a t-shaped cross-section with the cross of the t towards the light. That would remove a bunch of material and keep most of its strength. Maybe also give it a more finished look, depending on taste.
What’s the purpose of the short link with countersunk holes? So you can adjust the position of the handle relative to the light?
ETA: larger inside corner radii leading up to the boss with the counterbore where you screw to the light might look a little sleaker.
Profiling is 100% not happening.
The short link attaches to the GT mounting bracket and a handle or grip would mount to it like the 5/8” bar did on V1. Its countersunk on both sides for a 1/4-20 flat head socket screw, making it ambidextrous and adjustable.
And then he calls me out on the part I cheated on… The boss made it easy for me to make the mounting hole for the first one. I have a setup part now so that could be cleaned up for sure. A taper with a .750” radius top and bottom would look good I think.
Attractant.
Nectar of the flower to the bee.
I should probably test fit this thing with the V1 “grip” before it gets sent off to gi.lumens in the morning. At this point I can only assume the bracket fits the light…
Wow…… I think you nailed it!! . :+1:
Nice !!!
Got the samples in today, pretty dang cool! The access to the switch is perfect, or can be easily tweaked to suit ya…
Took too many pictures, bear with me…
These were apparently tumbled after being finished and it’s a nice look, I lined the inside of the bracket with a strip of black electrical tape, shaved the tape off on the sides to make it match the bracket, it fits on snug and protects the anodizing. All in all very well done and extremely useful.
I have some Titanium tubing I may use to make another handle, thread inside for a plug and thread the plug for the mount, should work and be strong and light weight.
Highly recommend this one, robust and plenty strong enough to not have to worry about.
Looking very good TBC…… :+1:
Wow! Nice work, TBC! :+1:
I like the easy switch access, and the ability to tweak the handle side to side. Great solution to suit righties and lefties.
Excellent pics, Dale! And plenty of them!
That’s why you send stuff to a professional photographer… yes they were tumbled Dale but not nearly as long as I would have liked.
TBC, what do you think, are these necessary to aid locking position of the handle and short wishbone?
Pinning with a stainless roll pin after adjusted :+1:
Sorry guys, I hadn’t used my 1DsMkII full frame Pro body in a while so I stuck the Hybrid IS 100mm Macro on it and had a bit of fun.
There are things that could be done to fine tune the aesthetic’s of these, but none of it would make it work better and it’d just gobble up a lot of time making them much more costly so right here where they’re at is plenty sufficient and they look nice, work beautifully.
You could pin it if you wanted I guess but it won’t move without some abuse. A drop of blue loctite on the joint would provide ease of mind if one was worried I guess.
Well put sir. The only change I can foresee is blending in the boss for the mounting screw which will cost nothing. It looks like the only thing left to do is a time study and to lean on the boss for a good price. Then the fact that I would need to come in on my own time as I now have at least a month worth of work that is needed by Feb 12. When I can make some time I think I want to make a small batch of just brackets (let’s say 20) and see where it goes. Anybody with a drill, a #7 drill bit and a 1/4-20 tap can make about anything a handle.
Very nice TBC. So the big question. When can I get one!!
I’ll reiterate. Are they still planned to be anodized?
Aluminum stinks to high heaven on the hands in the raw.
ARsee, it’s copper that makes the hands stink, not Aluminum. Lord knows I have barrels of Aluminum shavings that can attest to my experience with Aluminum making black hands but not stinky ones.
FWIW, copper is antibacterial, the smell when you handle it is the bacteria on your hands dying off. Smell the copper before you handle it, then after. It’s a product of your hands oils coming into contact with the anti-bacterial.
My chemistry is different. Bare aluminum stains my hands like lead. Lighter. With me, it has a warm, sterile odor.
Copper, is another story like you mention.
Love the look and have a friend that DuraCoats which might be a great solution for this. Quite likely I already missed the info, but in looking I couldn’t find any reference: is there a plan in place to get these produced and to Market? I would definitely be in for two so as to outfit both pending GT’s.
