Yes I know. I have already made improved version with bigger o-ring groove and gitd o-ring.
I mean can you fix stock o-ring between glass and bezel? (Is it proper size or no).
No
O-ring is smaller, not thick enough too.
Got it, will check original drawings and make changes.
Can you do a dropin for a c cell mag?
I dont feel Mag sets popular, but I can try to make any parts by custom drawing.
Any ideas how does same o-ring work with reflector?
I’m really curious what this will be. Any hints?
I will make real photos soon. But Ive already posted teaser from 3d model.
This project is made to have different usage, in this case I have to provide it as compete or almost complete set. Sorry for delays and not so budget price, hope nobody would be dissapointed with this step-up.
I don’t think I’ll be disappointed. It’s actually really good that you are trying step up your game and I’m curious to see the finished project.
Is our current guess that this is an entire replacement head?
Right.
Does it use stock C8 reflector or a larger one ?
Cute-3/4
Ohh , nice ! I can’t wait to see it’s awesome cooling fins :sunglasses:
Now for the million Ruble question. Did you source a copper MCPCB compatible with cute-4?
No. Only aluminium.
PM Sent for a Copper spacer Ultrafire F13 for Ledil Cute-3 triple
P60 solid Cu 18350 neck+S2+ Cu pill
What exactly is this? Thought at first a complete head, but closer look it is not…
This is P60 compatible neck with S2+ threads inside that can accomodate 18350 cell itself. I.e. if you take L2m (short tube) and change stock neck with this one, you will get 18650 cell place (few cm shorter than regular neck + long tube).
With included pill you can build quad with carclo optics, but if you have shorter pill you can make a single led config with some reflector or optics. Threads inside allows you to adjust pill at right height.
