Haikelite SC26 *** CLOSED For U.S.A. and Canadian Customers only*** Haikelite cut me off at 100 units so GB is closed.
I just added White to the drop down box... It was left out by mistake...
44
So far I do not have the actual CRI for the NW... Should have in a few days...
Can insert 6 pcs of 1.5mm x6 mm trit in the trit slots.
what is the dimension with 26650 battery?
also any chance that a XHP35 will fit in this?
Will a protected 26650 fit in this light, thank you
that was the smoothest internet transaction in recent memory. I love the 26650 battery lights
As far as I know yes... I can tell you more once the prototype arrives...
I just bought some 26650 batteries in anticipation for this light. The Shockli 5500mah and the Xtar 5000mah protected cell. They are the best unprotected and protected 26650 cells money can buy. I will probably use the Xtar protected cell most of the time (if it fits) and Shockli if I need extra capacity or lumens.
I'm partial to the purple Efest 26650...
I picked based off of HKJ’s battery comparator. Shockli seems to be the best one he tested so far. The Efest purple 2017 is a great cell and is close in performance to the Shockli. I have no idea which one is a more reliable brand.
http://lygte-info.dk/review/batteries2012/Common26650comparator.php
I think they both have certain areas they excel in that brings them close enough that either would be as good as the other except the Efest has lower capacity...
Any idea if the driver has over-discharge protection?
As far as I know it does but I will double check that... This would be a very important feature to overlook.
Just for my own personal knowledge I decided to check out a few local mega stores to see what kind of light $32.00 could buy a person.
I was so disappointed that the majority of customers (muggles) are content with purchasing a light rated at 300 to 400 lumen for this same price line and even a bit more.
I am going to have to set up a local event and show the general public just what they are missing when it comes to a small pocket sized EDC that can be purchased from $30.00 to 40.00.
1200 lumen would blow them away, imagine what 5k or 15k lumen would do.
The most fun part of what we do is show off lights lol....
Ordered
Okay the answer about battery protection is for sure yes it does have battery protection...
Even though I really don’t need another flashlight I ordered a green NW just because you reply to comments, and follow up quickly. Your awesome customer service will definitely bring you success!!!
I will continue following your future products.
Is that 26650 with the extention tube installed?
What is the beam angle? (I like floody lights)
Ordered. That was easy. Thank you!
