Only 20% discount code is available - see next post.
Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modes Flashlight Driver
Using coupon code FLSTNE lowers the price to $4.99.
Deal from here still works:
price is $18.87.
Not right now - I will try to get it.
There’s (non public) coupon code for:
Keeppower ICR26650 5200mAh 3.7v Protected Rechargeable Li-ion Battery 69.5cm
» PM me if you’re interested.«
There’s also a deal for Imalent protected cells - details in next post.
Imalent MRB-266P45 4500mAh 26650 Rechargeable Battery
Use coupon code FLSTNE for 20% discount - price drops to $12.64
DQG Hobi PLUS 10180 XP-G2 Multimaterial NW 3Modes USB Rechargeable Mini LED Flashlight
Use coupon code YGHP for 20% discount - price drops to $26.36 - $35.96 (depends on the material used).
Ordered 10pcs of A17DD.
Thank you.
Any coupon for this?
yeah i need some too
https://www.banggood.com/BLF-X6X5-Driver-ATTiny25V-Based-and-FET7135-Pow…
coupon?
Not yet - but will try to get one.
No coupons are available right now but I will try to get it.
Rofis MR70 XHP70.2 CW+XP-G2 NW 3500LM Dual Light Multifunction Rechargeable LED Flashlight +26650
Use coupon code YMR70 to lower the price by -$25.26
:arrow_right: 26650 5500mAh battery is included.
Klarus G20L XHP70.2 P2 3000Lumens Dual Switch Brightness USB Rechargeable LED Tactical Flashlight
Use coupon code PG20LA for 36% discount (-$39.58).
- Cree XHP70.2 P2 LED
- max 3000lm and 300m range
- USB rechargeable with 2A fast charging
- remaining battery capacity indicator (LED inside side switch)
- 2 switch design (tail click + side click)
- one touch turbo
- one touch low
- Intelligent Temperature Protection System
- included 5000mAh 26650 battery
- holster, lanyard ans USB cable included
ISDT C4 8A Touch Screen Smart Battery Charger With USB Output For 18650 26650 AA AAA Battery
Use coupon code ISDTC410 for additional 10% (–6.00$) discount
The charger is right now discounted for another 10$ (from $69.99 to $59.99) and final price after coupon is $53.99
This is advanced charger with great manual control over charging process.
- manual setting 100mA - 3000mA charging current (in 100mA steps)
- on-line temperature/voltage/capacity/current/internal resistance and voltage graph display
- Chemistries: Li-Ion, Ni-Mh, Ni-Cd, Ni-Zn, Li-HV, LiFePO4, Eneloop
- 25W max charge power (8A combined charge current, up to 3A/channel)
- Operation modes: Charge, discharge, storage, cycle, activation, analysis
- 10mV voltage measurement resolution
- USB power output: DC 5V/2.1A
- 320x240 IPS LCD display
- USB link for computer connectivity (updateable firmware)
Enlan M028 168mm 8CR13MOV Stainless Steel Blade Wood Handle Mini Folding Knife Outdoor Fishing Knife
It’s now in flash sale with 46% discount for $8.49 (was $15.84).
Offer is valid until Feb 17.
Enlan EL-06 212mm 8CR13MOV Stainless Steel Blade G10 Hanlde Multifunctional EDC Folding Knife
It’s now in flash sale with 35% discount for $15.99 (was $24.55).
Enlan M011 165mm 8CR13MOV Stainless Steel Blade Wood Handle Mini Pocket EDC Folding Knife
It’s now in flash sale with 48% discount for $7.79 (was $14.97).
Enlan M022 170mm 8CR13MOV Stainless Steel Blade Micarta Handle Mini Folding Knife Outdoor Army Knife
It’s now in flash sale for $10.99 (was $15.22).
Offer is valid for 1 day and 13 hours.
Enlan EW039 260mm 8CR13MOV Stainless Steel Blade G10 Handle EDC Folding Knife Outdoor Survival Knife
It’s now in flash sale for $32.99 (was $45.32).
