Your number is on #380 and #837
I do not see him registered
~~https://budgetlightforum.com/t/-/45538/2160~~
EDIT: Your number is on #950
Request on post #2166 : FW3A, a TLF/BLF EDC flashlight - SST-20 available, coupon codes public - #2160 by Riku :wink:
Thanks MascaratumB
Edit post
I edit list
Apologies
. EDIT: Your number is on #950
Editor
I’m # 796…and that’s the only place I see me…I had mentioned getting 2, so I don’t know if that would be 2 different spots or just the one…oh well…the Miller said “it’s done when it’s done”
The Miller assigned him nº. 343
pepinfaxera assigned him nº. 796
Your number is on #343 and #796
You could swap the settings. That way, normal “off” would have a dark button and lockout “off” would be illuminated. Or you could have them both dark. Or one high and one low, or both high or both low.
If it helps at all, lockout mode also functions as a momentary moon mode, which can be handy in the middle of the night. I find it useful when I wake up and want to see something without getting blinded.
Or maybe quick access to blinding turbo is desired? Is this an “in case of intruder” thing?
I probably just don’t understand your use case or what problem is being solved.
Didn’t realize I did it twice. Thank you.
As an extra interesting factoid, when in lightning mode the side switch mimics the primary emitter, within the 3 levels it has of course. :slight_smile:
Also, the side switch will glow in low level when the light is on utilizing the single 7135 chip and in high level when the ramp level passes the 7135 into the FET range. The switch light will also increase from low to high if ramping candlelight up beyond the 7135 chip. It makes it fairly easy to see what channel is in use. :wink:
Edit: This is in reference to Anduril, sorry I didn’t clarify.
Yeah. The FW3A doesn’t have a lighted switch, but on lights which do have one, it can be used to tell at a glance whether the light is at a regulated level or not. Anduril updates that as a side effect of changing the main emitter brightness, so it’s always completely in sync.
I did it that way because it was simple and easy, but I like how it turned out.
count me in for 1!
Lightbringer: The Miller has not included him in the list
Your number is on #106
You have ordered 2 units
The Miller put him in a
You want second unit
Mstevens113 The Miller has not included him in the list
I also don’t see myself on the list. I asked for 1 but now I would like to get 2. Is the list in the OP or where can I see the most updated list? Thanks.
You are number 844 on this post, updated by pepinfaxera:
After seeing your post above he will probably add you for the 2nd one.
I’m tempted to write an interest-tracking bot which would monitor the thread, look for specific types of messages, and maintain an interest list automatically. It’d require people to phrase their requests in very specific ways though… like “TKbot, sign me up for 2” or “Minion, cancel #456”.
Shouldn’t the list be maintained in the OP instead of burried in the thread? That way it’ll be easier for everyone to track.
Op went AWOL
Op went AWOL
