I’m # 796…and that’s the only place I see me…I had mentioned getting 2, so I don’t know if that would be 2 different spots or just the one…oh well…the Miller said “it’s done when it’s done”
You could swap the settings. That way, normal “off” would have a dark button and lockout “off” would be illuminated. Or you could have them both dark. Or one high and one low, or both high or both low.
If it helps at all, lockout mode also functions as a momentary moon mode, which can be handy in the middle of the night. I find it useful when I wake up and want to see something without getting blinded.
Or maybe quick access to blinding turbo is desired? Is this an “in case of intruder” thing?
I probably just don’t understand your use case or what problem is being solved.
As an extra interesting factoid, when in lightning mode the side switch mimics the primary emitter, within the 3 levels it has of course.
Also, the side switch will glow in low level when the light is on utilizing the single 7135 chip and in high level when the ramp level passes the 7135 into the FET range. The switch light will also increase from low to high if ramping candlelight up beyond the 7135 chip. It makes it fairly easy to see what channel is in use.
Edit: This is in reference to Anduril, sorry I didn’t clarify.
Yeah. The FW3A doesn’t have a lighted switch, but on lights which do have one, it can be used to tell at a glance whether the light is at a regulated level or not. Anduril updates that as a side effect of changing the main emitter brightness, so it’s always completely in sync.
I did it that way because it was simple and easy, but I like how it turned out.
I also don’t see myself on the list. I asked for 1 but now I would like to get 2. Is the list in the OP or where can I see the most updated list? Thanks.
I’m tempted to write an interest-tracking bot which would monitor the thread, look for specific types of messages, and maintain an interest list automatically. It’d require people to phrase their requests in very specific ways though… like “TKbot, sign me up for 2” or “Minion, cancel #456”.
The Miller has been absent since about Nov 20th. He is the only one who can change post one. At some point in the future we can have the moderator (forum owner SB) reassign post one to Team Fritz or whatever. Then it can be updated. We just haven’t got to that point, yet.
