Haikelite SC26 *** CLOSED For U.S.A. and Canadian Customers only*** Haikelite cut me off at 100 units so GB is closed.
As far as I know yes... I can tell you more once the prototype arrives...
I just bought some 26650 batteries in anticipation for this light. The Shockli 5500mah and the Xtar 5000mah protected cell. They are the best unprotected and protected 26650 cells money can buy. I will probably use the Xtar protected cell most of the time (if it fits) and Shockli if I need extra capacity or lumens.
I'm partial to the purple Efest 26650...
I picked based off of HKJ’s battery comparator. Shockli seems to be the best one he tested so far. The Efest purple 2017 is a great cell and is close in performance to the Shockli. I have no idea which one is a more reliable brand.
http://lygte-info.dk/review/batteries2012/Common26650comparator.php
I think they both have certain areas they excel in that brings them close enough that either would be as good as the other except the Efest has lower capacity...
Any idea if the driver has over-discharge protection?
As far as I know it does but I will double check that... This would be a very important feature to overlook.
Just for my own personal knowledge I decided to check out a few local mega stores to see what kind of light $32.00 could buy a person.
I was so disappointed that the majority of customers (muggles) are content with purchasing a light rated at 300 to 400 lumen for this same price line and even a bit more.
I am going to have to set up a local event and show the general public just what they are missing when it comes to a small pocket sized EDC that can be purchased from $30.00 to 40.00.
1200 lumen would blow them away, imagine what 5k or 15k lumen would do.
The most fun part of what we do is show off lights lol....
Ordered
Okay the answer about battery protection is for sure yes it does have battery protection...
Even though I really don’t need another flashlight I ordered a green NW just because you reply to comments, and follow up quickly. Your awesome customer service will definitely bring you success!!!
I will continue following your future products.
Is that 26650 with the extention tube installed?
What is the beam angle? (I like floody lights)
Ordered. That was easy. Thank you!
I want a green one, but alas I’m under a buying embargo.
I'm honestly not sure of the beam angle but I will find out for you.
I can tell you this is a smooth reflector more of a thrower. Close to 500 meters at only 1200 lumen.
Sorry I left out the answer about he battery tube... I am not sure which tube it will have installed when it ships but, You get tubes for both Cells the 23650 and 26650 both..
You still have plenty of time... and once these arrive I will be keeping a good stock of them...
Is the “Dimension: 3.3 inch length” with 26650 tube or the 26350 tube?
Thanks very much...
As soon as I get the prototype I can measure it exactly for you...
Ordered in green for my wife…
