Yes, if you have a reasonably good multimeter you can measure the parasitic drain directly without a lot of work, although you might need a second set of hands to hold wires in place.
I double checked with the meter, it reads 7ma for about 3 seconds, then it drops down to something like 0.25ma. Its got to be the atiny powering down? Anyway… I’m going to make sure to loosen the body before storage from now on…
Yes, that is exactly what should happen. I think it is 5 second that the MCU says powered up and after that it goes to sleep mode to reduce power down to around 0.25ma like you saw.
Which should get you over 1.5 years with 4 cells or twice that with 8 cells.
No idea why yours died so fast.
Locking out any e-swich light is the est idea if it will not be used for awhile.
I have Issues with the anodisation on my today arrived GT.
There are scratches on the Pill-section and on the first fin of the reflector on both sides of the Pill.
It seem that the Tool is verry dirty and makes scratches.
Pommie, I had the same thing going on with the two I bought, I started with Harbor Freight strap wrenches but had to buy two sets just so I would have 2 large wrenches and snapped both of those, then bought some other of Amazon and broke them as well.
I’ve seen this wrench mentioned before on one of the GT threads but this is definitely worth mentioning again because with this wrench the GT came apart easily.
It’s on Amazon called the BOA Constrictor, it’s more expensive than the others but it works great, BOA strap wrench
Edit: You might need 2 of them really, but it worked well using the big Harbor Freight strap wrench to hold the light in place and this BOA for for breaking the bezel and heat fin sections apart.
Knowing the person I borrowed them from they would be mid priced, not top quality but they were all metal so not cheap either, all I have to do now is ask that person what I owe him to buy two replacements :money_mouth_face:
I will find a way, even if I damage it more :smiling_imp: I got it to mod which I cannot do if I can’t get into it.
Now I have found a dead led-die on my gt. I can see it with my eyes if I look to the LED at the lowest mode.
Is this the first DOA-GT?
Thats hard to check for Lumintop and to notice that fault.
Here you can see the spot at a distance of 1.5m:
I put a lens on the GT to show the LED better:
And here you can see, what the lens is projecting:
Well if one of the four dies is less efficient you geht less light for the same current.
Maybe it was on the edge off the spec when Cree selected the four dies?
Well, it is sure not nice, but dead on arrival?
Versuch mal die LED direkt zu fotografieren, unterbelichtet und mit nem ND-Filter
Very strange indeed, this is also the first I have heard of any major issues with any GT so far. Everything else have been minor things.
Like they said, it is very strange that 1 die would burn out while the rest still work. Can you get a picture of the LED itself? Maybe on moon mode as well.
