I’m # 796…and that’s the only place I see me…I had mentioned getting 2, so I don’t know if that would be 2 different spots or just the one…oh well…the Miller said “it’s done when it’s done”
You could swap the settings. That way, normal “off” would have a dark button and lockout “off” would be illuminated. Or you could have them both dark. Or one high and one low, or both high or both low.
If it helps at all, lockout mode also functions as a momentary moon mode, which can be handy in the middle of the night. I find it useful when I wake up and want to see something without getting blinded.
Or maybe quick access to blinding turbo is desired? Is this an “in case of intruder” thing?
I probably just don’t understand your use case or what problem is being solved.
As an extra interesting factoid, when in lightning mode the side switch mimics the primary emitter, within the 3 levels it has of course.
Also, the side switch will glow in low level when the light is on utilizing the single 7135 chip and in high level when the ramp level passes the 7135 into the FET range. The switch light will also increase from low to high if ramping candlelight up beyond the 7135 chip. It makes it fairly easy to see what channel is in use.
Edit: This is in reference to Anduril, sorry I didn’t clarify.
Yeah. The FW3A doesn’t have a lighted switch, but on lights which do have one, it can be used to tell at a glance whether the light is at a regulated level or not. Anduril updates that as a side effect of changing the main emitter brightness, so it’s always completely in sync.
I did it that way because it was simple and easy, but I like how it turned out.
I also don’t see myself on the list. I asked for 1 but now I would like to get 2. Is the list in the OP or where can I see the most updated list? Thanks.
You are number 844 on this post, updated by pepinfaxera:
I’m tempted to write an interest-tracking bot which would monitor the thread, look for specific types of messages, and maintain an interest list automatically. It’d require people to phrase their requests in very specific ways though… like “TKbot, sign me up for 2” or “Minion, cancel #456”.
Shouldn’t the list be maintained in the OP instead of burried in the thread? That way it’ll be easier for everyone to track.
The Miller has been absent since about Nov 20th. He is the only one who can change post one. At some point in the future we can have the moderator (forum owner SB) reassign post one to Team Fritz or whatever. Then it can be updated. We just haven’t got to that point, yet.
Tk I think that would save a ton of time and confusion and work on a lot of people. If anyone can figure out a way to overcome all the issues left to work it is you. Thanks for your efforts.
Hum, I guess it would be a nice idea. Maybe the only problem is the different ways people say they want to be interest list:
- I’m in for N / I’m in
- I want N
- Please put me in the list / Please add me to the list /
- Sign me up for N
- Put me down for N
- I’d be interested in N / I am interested in N
- Count me in for N
- 1 please / N please
These are only some ways people say they want the FW3A. Also, despite the “bot”, wouldn’t it be necessary to re-check everything again to fill the gaps?
It is a brilliant idea, though
As a bedside lamp, lockout ain’t good.
OP, Can you add me to the list please?
I thought I posted I wanted one and somehow I don’t see my post any more.
The list on the Original Post is not updated as The Miller has been away for some time!
Member pepinfaxera is updating the list on this post:
http://budgetlightforum.com/comment/1255477#comment-1255477
Your number is on #956 already listed on that post
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S / A8 ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 TIR Lenses: 1 / 2 Others: Biscotti 3 & 1*7135 Triple TIR & XP-G2
MY GIVEAWAY (FW3A)
Thanks for the update!
Your number is on #380 and #837
Sorry for my bad English
(google translator) , (https://www.deepl.com/translator)
I do not see him registered.
http://budgetlightforum.com/comment/1259478#comment-1259478.
EDIT: Your number is on #950
Request on post #2166 : http://budgetlightforum.com/comment/1259478#comment-1259478
MY GIVEAWAY (FW3A)
Thanks MascaratumB
Edit post
I edit list
Apologies
. EDIT: Your number is on #950
Editor
- – change to —
RT- – = RT— See Post #950 http://budgetlightforum.com/comment/1255477#comment-1255477
Your number is on #343 and #796
Didn’t realize I did it twice. Thank you.
count me in for 1!
Brian C
Your number is on #106
You have ordered 2 units
The Miller put him in a
You want second unit
After seeing your post above he will probably add you for the 2nd one.
MY GIVEAWAY (FW3A)
Op went AWOL
-the- Throw calculator - Pulsars list
Op went AWOL
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, TA FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, TA FET driver, NarsilM v1.0 ramping UI, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube and Maukka Calibration Lights for DIY Lumen Measuring Devices
Headlight List with prices, specs and features - Jaxmnve M1 Stainless 10180 Keychain light Review - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
I have the beginning of an interest-list bot. It’s a long way from being usable, but at least it does a few things so far:
However, it does not yet:
So it’s a super early proof of concept and there’s much left to do. Anyway, it’ll probably turn out something like this…
… except probably less chipper and less chatty, since talkative bots tend to end up like this:
- I want N
- Sign me up for N
- Put me down for N
- Count me in for N
MY GIVEAWAY (FW3A)
Thought I was on the list, didn’t see my name…
Interested in 1-2 depending on final details and release timetable.
(sorry my interest didn’t follow any of the others as noted above)
I guess this is your first post on the thread
Member pepinfaxera will add you name later here.
THE LISTS ARE ON THESE POSTS:
The Miller (Original Post, 763 entries, 10-30-2017): http://budgetlightforum.com/node/54239
pepinfaxera (continuation and updated list after entry #764 and corrections): http://budgetlightforum.com/comment/1255477#comment-1255477
MY GIVEAWAY (FW3A)
