The design is so appealing, it’s a beauty!
The white (looks silver to me) could’ve been plucked out of Taylor’s backpack in the original Planet of the Apes. Ordered a yellow but considering a white to keep the other cell in. Ugh.
The price will go up some after this pre-sale but they will still be very affordable... I have already decided that I want to give several of these out as Christmas gifts. My only problem is muggles.
The ramping U.I. is super simple to use but having to explain lithium Ion cells and why they must use a bit more caution and attention is where it becomes the hardest.
Any plans for offering SC26 type body with different emitter(s)?
I’m thinking the current pocket rocket kings have some major shortcomings, shortcoimings that an SC26 like host could overcome.
Specifically, the D4 suffers from very short high ouput runtimes and poor heat management.
Tiny 26650 3th is less bright than D4 and suffers from quality control issues.
Neither of them have much throw.
The slighly larger SC26 body style (with significanly larger capacity battery) could surpass both these lights, and offer a smaller 26350 ff when even smaller matters.
I do like the SC26 form factor, AND I want a small pocketable light that can do 3000 lumen (for more than a few seconds), and I want a reflector. I suspect this could be a popular combo- look how popular the D4 is.
The other lights I’ve seen similar to my desired specs are at least 2 of the following 3:
substantially larger;
substantially more expensive;
offer only CW tint.
And none offer a stubby 26350 option.
Let me rephrase:
small as possible with modest reflector.
2500+ lumen
Good runtimes (26650)
able to become smaller, of course sacrificing much runtime and/or brightness (26350)
CW, NW, WW options.
So, I nominate Haikelite. Perhaps they could just adapt an XHP50.2 or XHP70.2 into SC26?
I typically try to actually provide or at least provide links to adequate chargers/batteries, and give a speech, something to the extent, “only charge on relatively fireproof surfaces with no readily flammable objects nearby, including above.” I like to throw in the hand grenade analogy too. That usually puts the fear of [higher power(s)] in them.
Well, to get any of the emitters to work that you listed it would need a boost driver. I think if they put a boost driver in it, it would make an awesome MTG2 light lol
